Both the freezer and refrigerator quit cooling. Fan motor at bottom rear of cabinet is running all the time. I can unplug the unit/or turn control to off for a couple of minutes and then turn it back on and it will run for a little while. It even makes a little ice. Any ideas? Thanks in advance for your help.
Sounds like your compressor is seizing after a short run.Pull the off and check. If so, a tech. can put in a supco oil additive (Supco 88) that will fix this.
