csinshaw
#1 Posted : Monday, December 17, 2012 5:57:55 PM(UTC)
csinshaw
I have tried a couple postings and so far no responses. I could really use any help you can provide.
I have a Whirlpool washer LSC5000PQ2 that stops at the end of the wash cycle (previously I thought it was at the end of the rinse cycle). The tub empties, but does not go into the rinse mode. If I turn push the knob in and pull it back out then it restarts.
My wife also seems to think that is is not getting as much water out during the final spin which is making the dryer run much longer to get the clothes dry.
I am thinking it is either a bad timer or level switch. I would appreicate any thoughts or ways to narrow down the cause. I am hoping to have this unit last a few years more. I just recently replaced the pump (which was leaking), and don't relish having to throw another $100+ for a timer if I don't need to.
Chris
Fresno, CA
fairbank56
#2 Posted : Tuesday, December 18, 2012 5:40:15 AM(UTC)
fairbank56
Groups: Expert
If it fills and agitates ok, then the water level switch is fine. Problem appears to be in the timer.
Eric
csinshaw
#3 Posted : Tuesday, December 18, 2012 11:36:50 AM(UTC)
csinshaw
Does the level switch sense the lower level to indicate it is ready to fill at the start of the rinse cycle or have a higher speed spin at the end?
fairbank56
#4 Posted : Tuesday, December 18, 2012 12:30:46 PM(UTC)
fairbank56
Groups: Expert
It is possible that there is some gunk in the air dome or air hose located on the right rear quadrant of the outer tub interfering with the switch operation but this is unlikely the problem. The switch is either in the full position or empty position. This switch has nothing to do with the spin cycle as the switch is bypassed by the pressure switch bypass contacts in the timer during drain/spin mode.
Eric
30+ Yr. Old GE Washer- Need Advice (Washer Repair)
by Not_Handy 7/24/2016 3:05:59 PM(UTC)
Kenmore Washer --- stumped... NEED ADVICE! (Washer Repair)
by rlhfixit 6/5/2015 12:37:35 PM(UTC)
Relay Burnt Out. Need Advice (Dryer Repair)
by Schradermt 2/27/2015 7:43:40 AM(UTC)
Whirlpool Side By Side Cooling Issues Need Advice....... (Refrigerator & Freezer Repair)
by CaptainWarmFridge 6/22/2014 1:58:09 PM(UTC)
please need advice (Dryer Repair)
by mikegurley81 12/1/2013 8:20:09 AM(UTC)
Leaking washer need advice (Washer Repair)
by GE Nightmare 10/5/2013 1:54:30 PM(UTC)
Need Advice!!!!!! (Refrigerator & Freezer Repair)
by piscesbound 2/8/2013 12:32:56 PM(UTC)
Need advice on Kenmore upright freezer (Refrigerator & Freezer Repair)
by rgraff 12/13/2012 6:18:44 PM(UTC)
Washer won't agitate, spin or drain - need advice! (Washer Repair)
by BlueSapphire 8/7/2012 7:52:27 AM(UTC)
Need advice on a Whirlpool (Dryer Repair)
by mclldavidson 3/29/2012 1:29:44 PM(UTC)
Freezer on top model- Evap not getting cold - need advice (Refrigerator & Freezer Repair)
by WI-landlord 3/7/2012 10:08:38 AM(UTC)
Need advice on what to check: dryer not drying (Dryer Repair)
by antessima 12/1/2011 5:14:45 PM(UTC)
fixing fridge, need advice (Refrigerator & Freezer Repair)
by Big Bigby 9/2/2011 2:20:55 AM(UTC)
Need Advice: Is the tech correct? (Refrigerator & Freezer Repair)
by mealto 5/4/2011 7:56:39 AM(UTC)
Need advice with repairing my fridge/ defrost timer (Refrigerator & Freezer Repair)
by rubyvega 11/17/2010 11:44:48 AM(UTC)
