Frits6
#1 Posted : Monday, December 17, 2012 4:15:29 PM(UTC)
Frits6
Dryer will tumble without heat. The first time I found that the high limit thermostat had melted and i replaced it. I got heat for a few minutes then cold air. I just now replaced the high limit and the low limit (?) thermostat with the hope that this would do it...nope. The high limit had no connectivity either time. The low limit did but I thought maybe it had malfunctioned anyway. So I am out of ideas. The ducts are clear. Any ideas?
#2 Posted : Tuesday, December 18, 2012 1:30:13 PM(UTC)
Did it show any error code?
How did you know that the vents are clean and the air flow is not obstructed?
Frits6
#3 Posted : Tuesday, December 18, 2012 2:12:44 PM(UTC)
Frits6
No sir. No error codes. When I replaced the thermostats i checked to see that hot air was blowing through the duct work. Didn't seem to be a problem.
#4 Posted : Tuesday, December 18, 2012 3:07:20 PM(UTC)
Run the temperature test as instructed in the attached file (page 5) with the vent hose still connected to the dryer and with the vent hose disconnected from the dryer and post the results.
File Attachment(s):
Samsung-Dryer-DV2x - 3x - Fast-track.pdf (886kb) downloaded 2 time(s).
Replaced oven element in 7 year old Whirlpool stove and still no heat (Oven Repair (including Ranges and Cooktops))
by Guest 4/14/2021 2:34:36 PM(UTC)
Replaced oven element and still no heat (Oven Repair (including Ranges and Cooktops))
by Guest 4/14/2021 2:32:26 PM(UTC)
All parts have continuity still no heat (Dryer Repair)
by Goineson 12/9/2017 9:29:35 PM(UTC)
by Goineson 12/9/2017 9:28:56 PM(UTC)
Replaced/tested everything - still no heat - (Dryer Repair)
by Snug Harbor 2/23/2015 7:29:12 AM(UTC)
Checked thermo stats, power source, heating element, still no heat (Oven Repair (including Ranges and Cooktops))
by rickortenblad 4/15/2014 9:10:58 AM(UTC)
Replaced Temp sensor, still no heat (Oven Repair (including Ranges and Cooktops))
by Hypnocrip 2/21/2014 12:34:27 AM(UTC)
GE Replaced Gas Valve Coils - Still no heat (Dryer Repair)
by ScottKr 8/10/2013 10:55:48 AM(UTC)
Replaced heating element and still no heat. (Dryer Repair)
by freqflyer 5/17/2013 7:53:48 AM(UTC)
by uncledale1031 4/2/2013 10:54:57 AM(UTC)
replace element and tested everything still no heatzs (Oven Repair (including Ranges and Cooktops))
by grmbmg 4/12/2012 9:05:13 PM(UTC)
New Parts and still no Heat!!!! (Dryer Repair)
by larosa00 10/29/2011 5:37:59 PM(UTC)
Everything checking out still no heat? (Dryer Repair)
by max32111 7/10/2011 9:16:57 AM(UTC)
After changing magnatron and diode still no heat (Microwave Repair)
by Srizvi5 4/3/2011 6:05:12 PM(UTC)
Tappan range oven burnt element/replaced/ still no heat (Oven Repair (including Ranges and Cooktops))
by bandit571 2/11/2011 12:56:41 PM(UTC)
