btv268
#1 Posted : Saturday, December 8, 2012 6:43:14 PM(UTC)
btv268
I have a GE WVSR1060A1WW top load washer that is probably 10years old and the spin cycle stopped working. The agitate cycle works but whenit goes to the spin cycle, the water drains and then nothing. I have checked thelid switch and it is working. I removed the front cover and saw that when thespin cycle engages, the motor jerks but nothing else. I removed the belt andthe motor seems to function fine in the spin cycle with no stress on it. I handturned the agitator shaft in both directions and it moves but not freely. Anysuggestions as to what my next move should be?
Thanks.
fairbank56
#2 Posted : Sunday, December 9, 2012 4:15:06 AM(UTC)
fairbank56
Groups: Expert
You say "the motor jerks but nothing else", is the motor spinning? i.e. is the clip on the bottom of the motor shaft below the pulley spinning? or does the motor just stop? If stopped, is it humming? With the belt removed, the motor spins fine in spin? With belt on, you should be able to rotate the motor pulley easily in each direction however, in the spin direction (CW looking from below) it will be a little more difficult as the entire transmission and basket will rotate.
Eric
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
GE Washer Wont Spin or Agitate (Washer Repair)
by rangerjoey76 12/8/2013 11:55:34 AM(UTC)
ge washer wont spin (Washer Repair)
by malcolm12 6/8/2012 10:04:15 AM(UTC)
GE washer wont spin (Washer Repair)
by rich bean 3/21/2012 10:25:32 AM(UTC)
by briwill99 12/29/2011 10:42:36 AM(UTC)
by blizzzz 10/5/2011 6:11:31 PM(UTC)
by memin 3/28/2011 9:41:11 AM(UTC)
ge washer wont spin in rinse (Washer Repair)
by crownjason 3/9/2011 7:24:03 AM(UTC)
GE Washer wont spin (Washer Repair)
by ruddle38 7/14/2010 5:55:24 AM(UTC)
by Wedge 73 11/26/2009 3:50:55 AM(UTC)
GE washer wont spin belt appears loose (Washer Repair)
by parkman009 6/17/2008 8:43:16 PM(UTC)
