Lynn Wachter
#1 Posted : Thursday, December 6, 2007 7:55:03 AM(UTC)
Lynn Wachter
My GE Spectra XL 44 gas oven does not maintained proper heating. How do I determine if the problem is a sensor, igniter or thermostat? Any sugggestions?
#2 Posted : Thursday, December 6, 2007 3:10:29 PM(UTC)
In order to provide the most accurate advise I need the complete model number of the range. You can find it on the frame behind the bottom drawer. XL44 is not a model number.
Lynn Wachter
#3 Posted : Tuesday, December 11, 2007 9:36:47 AM(UTC)
Lynn Wachter
Gene,
The model number for my GE XL 44 is JGBP31WEC4WW, serial number SD232600P.
Thank You.
#4 Posted : Tuesday, December 11, 2007 10:32:18 AM(UTC)
Lynn
Does it heat up at all?
If it does, what is the difference between the real temperature and the set temperature?
If it does not heat up, check if 120V is coming to the oven igniter when the control calls for the heat.
If there is 120V then the igniter has to be replaced.
If there is no 120V then the control board has to be replaced.
If the difference between the real oven temperature and the set temperature is within 35 degrees range - it could be calibrated.
You can find the instructions in the "Use and care" manual (page 21).
- The part number for the oven igniter AP2014008
- The part number for the control board AP2632480
Samsung dv220agw - heating problem (Dryer Repair)
by jjandrews222 3/8/2021 6:18:21 PM(UTC)
Electric Admiral Dryer heating problems. (Dryer Repair)
by ShaneBurle24 7/12/2018 8:32:23 AM(UTC)
Whirlpool Gas Dryer Heating Problem (Dryer Repair)
by rinkugaya 9/24/2016 3:17:35 PM(UTC)
Dryer heating problem (Dryer Repair)
by Doehr 8/28/2016 10:41:56 AM(UTC)
Oven Heating Problem (Oven Repair (including Ranges and Cooktops))
by Jman1 1/20/2016 4:33:59 PM(UTC)
Roper dryer heating problems (Dryer Repair)
by laurencp72 1/19/2016 4:58:28 PM(UTC)
Kenmore Elite HE3 gas heating problems (Dryer Repair)
by karl1970 12/24/2014 6:39:08 PM(UTC)
Intermittent heating problem with gas dryer (Dryer Repair)
by David L. Mandel 8/16/2014 8:21:23 PM(UTC)
Diagnosing Heating Problem (Dishwasher Repair)
by glmoore0001 2/18/2014 10:16:59 AM(UTC)
oven heating problem (Oven Repair (including Ranges and Cooktops))
by 9point1 11/20/2013 9:30:19 AM(UTC)
LG LSE3092ST Oven Heating Problem (Oven Repair (including Ranges and Cooktops))
by parabola 10/8/2013 8:51:33 AM(UTC)
maytag stacked Dryer heating problem. (Dryer Repair)
by yudule 8/13/2013 10:30:40 AM(UTC)
by HOLLYTIM 6/11/2013 5:41:18 AM(UTC)
Need more help with dryer heating problems (Dryer Repair)
by Steves9411 4/12/2013 4:53:45 AM(UTC)
Heating Problem Issues (Dryer Repair)
by dmikel12 10/8/2012 4:01:27 PM(UTC)
