Bandola81
#1 Posted : Saturday, November 24, 2012 3:19:32 PM(UTC)
Bandola81
Hi my frezer is not cooling, i check compresor and fan is woorking, compresor is hot. Please let me now what next i should check, thank You
rickgburton
#2 Posted : Saturday, November 24, 2012 3:55:53 PM(UTC)
rickgburton
Groups: Expert
Unplug the machine and remove the start device from the side of the compressor and shake it. If it rattles or starts to fall apart in your hands, it's bad and needs to be replaced.
Bandola81
#3 Posted : Saturday, November 24, 2012 5:05:07 PM(UTC)
Bandola81
I checked, looks like new, i plug fridge again to power and main board click, compresor and fan starts, but i notice main board make some noise, also Inside fridge fan is not run i think
Bandola81
#4 Posted : Saturday, November 24, 2012 5:06:50 PM(UTC)
Bandola81
Compresor is very hot but work
Bandola81
#5 Posted : Sunday, November 25, 2012 6:10:23 AM(UTC)
Bandola81
I notice ice built on the evaporator coils. What i should check now?
Opened up back panel tonight to check on defrost system. Disconnected defrost heater at both ends and checked continuity accross it. Measured 23 ohms.
Next checked defrost thermostat it was 10 ohms
rickgburton
#6 Posted : Sunday, November 25, 2012 1:45:11 PM(UTC)
rickgburton
Groups: Expert
If the heater and thermostat check good, replace the control part# Part number: 2321710
Bandola81
#7 Posted : Sunday, November 25, 2012 3:11:46 PM(UTC)
Bandola81
thank you, i just order this part i let you now if works, thx
Guest (5)
Refrigerator is not cooling enough (Refrigerator & Freezer Repair)
by anil_rathore 4/18/2016 10:38:10 AM(UTC)
Refrigerator is not cooling (Refrigerator & Freezer Repair)
by Lousgirl 11/22/2013 4:58:18 PM(UTC)
My refrigerator is not cooling/running consistently (Refrigerator & Freezer Repair)
by Whirlpool_fridge 12/30/2011 6:43:13 PM(UTC)
by Amir 9/6/2009 9:17:56 PM(UTC)
freezer is working but bottom refrigerator is not cooling (Refrigerator & Freezer Repair)
by jnsaiz 8/19/2009 7:33:58 PM(UTC)
