house Dr.
#1 Posted : Monday, November 19, 2012 5:25:56 AM(UTC)
house Dr.
The refrigerator is freezing food in the fridge compartment with the control on 1. I have replaced the defrost timer and the temp control was replaced a few years ago. My son in law replaced the thermostat a couple years ago. I have checked the temp control and it seems to be working properly. I used an ohm meter to check it. I then placed the temp control in a working freezer and it had the correct reading. Any suggestions?
#2 Posted : Monday, November 19, 2012 9:38:36 AM(UTC)
Parts for Frigidaire FRT18TPHW0 Refrigerator - AppliancePartsPros.com
[COLOR="Blue"]
I have replaced the defrost timer[/COLOR]
A defrost problem would have caused the fresh food section to be too warm.
[COLOR="Blue"]and the temp control was replaced a few years ago. My son in law replaced the thermostat a couple years ago.[/COLOR]
I am assuming both the above are referring to the main temperature control thermostat
[COLOR="Blue"]I have checked the temp control and it seems to be working properly. I used an ohm meter to check it. I then placed the temp control in a working freezer and it had the correct reading.[/COLOR]
I am not sure how you did the test or how you determined it was OK.
Check that the evaporator/freezer fan is running. It should be on whenever the compressor is on. It is required for proper air circulation in the unit.
I am assuming that the compressor is cycling normally (not on all the time) though it may run longer than it used to.
Odds are that it is a main thermostat problem.
Simon / APP Team
#3 Posted : Monday, November 19, 2012 9:45:21 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Adjust the air flow from the freezer to a minimum if possible.If still will be too cold - replace the cold control Part number: 5304404821
Here are the breakdown diagrams and Shelves parts for Frigidaire FRT18TPHW0 - AppliancePartsPros.com
Post the results.
Simon.
#4 Posted : Thursday, November 22, 2012 10:23:32 AM(UTC)
If the fridg is running constantly, your freezer temperature should be well below zero, just check.
Maytag Refrigerator freezing food on lowest setting (Refrigerator & Freezer Repair)
by ilgy 2/15/2024 8:14:17 AM(UTC)
Samsung Refrigerator freezing food (Refrigerator & Freezer Repair)
by Dozerxy 1/17/2022 2:30:40 PM(UTC)
Some areas of refrigerator freezing food (Refrigerator & Freezer Repair)
by bluefitness 10/6/2018 8:05:06 AM(UTC)
by Wingalsbeiii 12/29/2015 6:52:45 AM(UTC)
Refrigerator freezing food when ice maker working (Refrigerator & Freezer Repair)
by trout14 4/11/2015 2:57:37 PM(UTC)
Refrigerator Freezing Food on Lowest Setting (Refrigerator & Freezer Repair)
by TomMant 5/10/2014 4:25:00 AM(UTC)
by ltrager 4/2/2014 7:13:21 AM(UTC)
Refrigerator freezing food. Bottom freezer OK. (Refrigerator & Freezer Repair)
by DMand 3/11/2014 7:48:43 AM(UTC)
Samsung RB215LABP refrigerator freezing food (Refrigerator & Freezer Repair)
by Steve Dams 7/15/2013 8:50:11 AM(UTC)
Kenmore refrigerator freezing food (Refrigerator & Freezer Repair)
by onesocalguy 1/28/2013 7:42:18 PM(UTC)
Refrigerator Freezing Food (Refrigerator & Freezer Repair)
by mowman29 8/28/2012 4:50:08 PM(UTC)
by eric54 10/1/2011 6:31:37 AM(UTC)
GE Eterna Refrigerator Freezing Food (Refrigerator & Freezer Repair)
by mikekoll 12/5/2009 2:36:19 PM(UTC)
by nanj2911 7/17/2009 3:09:18 PM(UTC)
Kenmore Elite Coldspot 106.74203401 refrigerator freezing food (Refrigerator & Freezer Repair)
by Gill78ight 5/12/2009 12:58:36 PM(UTC)
