bobby6432
#1 Posted : Friday, October 26, 2012 3:28:27 PM(UTC)
bobby6432
this oven worked fine for years, but suddenly both bake and broiler elements won't heat. i suspect the switch or the thermostat and i have a test meter, but don't know which wires should show continuity. would a wiring schematic show me what to test? or is there another way?
Simon / APP Team
#2 Posted : Friday, October 26, 2012 3:59:51 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the model number. It's probably MCM255. If that's so check the hi-limit cutoff thermostat, located at the back of the oven. It should have continuity. #141 on the diagram
04-Oven Body parts for Thermador MCM255 - AppliancePartsPros.com
Post the results.
Simon.
bobby6432
#3 Posted : Saturday, October 27, 2012 11:05:24 AM(UTC)
bobby6432
You are right: MCM255. Very hard to read. I will not be able to pull the unit out of the wall by myself. So maybe I will need to call a repairman.
Simon / APP Team
#4 Posted : Saturday, October 27, 2012 2:50:35 PM(UTC)
Simon / APP Team
Groups: APP Team
Good luck to you.
Simon.
Whirlpool range oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by Guest 5/10/2021 12:58:16 PM(UTC)
Lower Oven doesn't heat properly (Oven Repair (including Ranges and Cooktops))
by Softballfan 4/16/2016 1:45:41 PM(UTC)
fridgidaire oven doesn't heat up (Oven Repair (including Ranges and Cooktops))
by debshroom 5/8/2013 7:15:43 AM(UTC)
upper oven doesn't heat up (Oven Repair (including Ranges and Cooktops))
by stephen36 2/25/2013 11:57:09 AM(UTC)
Whirlpool SB130PER4 Gas Wall oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by sikhnerd 10/17/2012 10:00:32 AM(UTC)
Oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by dskar 6/10/2012 5:16:27 AM(UTC)
by Silvernick 5/15/2012 8:20:59 PM(UTC)
oven doesn't heat to selected temp. (Oven Repair (including Ranges and Cooktops))
by jimsmithbc 10/31/2011 1:54:50 PM(UTC)
Magic Chef gas oven doesn't heat up (Oven Repair (including Ranges and Cooktops))
by jand 7/1/2011 9:23:12 AM(UTC)
Oven doesn't heat after bright flash (Oven Repair (including Ranges and Cooktops))
by markmelancon 6/17/2011 11:10:57 AM(UTC)
Electric Range oven doesn't heat - stove top works (Oven Repair (including Ranges and Cooktops))
by deannastevens70 3/2/2011 8:54:15 PM(UTC)
GE Oven doesn't heat after using self clean (Oven Repair (including Ranges and Cooktops))
by Elmo1 2/3/2011 4:57:50 PM(UTC)
GE oven doesn't heat up everytime (Oven Repair (including Ranges and Cooktops))
by IntermittentGE-Oven 12/20/2010 3:49:12 PM(UTC)
Magic Chef oven doesn't heat (Refrigerator & Freezer Repair)
by Francisco Dan 12/7/2010 12:46:57 PM(UTC)
Oven doesn't heat to temperature (Oven Repair (including Ranges and Cooktops))
by msdahl 11/5/2010 11:41:01 AM(UTC)
