daddyrog
#1 Posted : Monday, October 8, 2012 8:49:47 AM(UTC)
daddyrog
i have a upright freezer; not sure of model; not where i can look right now; this freezer works great untill i have power outtage; even the shortest flicker will cause it to quit working; then i unplug to reset and it is fine untill i have another outtage then i have to reset again; been doing this for about 2 years and no problems; but my son now lives in the house where it's at and i'm afraid he will forget to reset it and lose everything.
Just wondering if there is a fix for it and if so; is it worth the trouble;
any and all info greatly appreachated.
daddyrog
#2 Posted : Wednesday, October 24, 2012 5:02:17 AM(UTC)
daddyrog
over 100 views and no replys; please need help; I'm sure it's probally a relay or something but don't know what; thanks daddyrog.
#3 Posted : Wednesday, October 24, 2012 7:35:21 AM(UTC)
If this is an inexpensive freezer with no self defrost, it's possible the cold control is defective and will not auto-turn on once power is restored.
If an expensive one with a defrost control, check for a service sheet behind the front kick panel. Will give diagnostics for this problem.
daddyrog
#4 Posted : Wednesday, October 24, 2012 10:26:33 AM(UTC)
daddyrog
It is a kenmore frostfree; no service sheet to be found
#5 Posted : Thursday, October 25, 2012 12:18:35 AM(UTC)
Look for a control module, probably bad.
#6 Posted : Thursday, October 25, 2012 12:42:50 AM(UTC)
This is difficult to give a fix, a model number may help.
Post it if you can get it.
Find your model number - AppliancePartsPros.com
Even with the number it probably will just be a guess.
richappy: Have you ever seen this problem?
Seems to me very weird as a power outage would be the same as unplugging the unit which he has to do to get it to work.
Perhaps the best solution is to get a freezer alarm, just Google it.
It would give an alarm if the temperature gets too warm.
Problem is that it is useless unless you are at home.
#7 Posted : Thursday, October 25, 2012 1:15:58 AM(UTC)
I have seen burnt connections that re-connect when power is removed, then turned on. Have seen cold controls do this also.
daddyrog
#8 Posted : Thursday, October 25, 2012 5:19:32 AM(UTC)
daddyrog
mod. # 253-26452100
Thanks to all for the help; daddyrog.
I might add that if the power outtage is for more than 30 min. it might would start back ok; never tried it; but with a very short outtage it takes unpluging to get back started; like it has to reset or something.
#9 Posted : Thursday, October 25, 2012 8:20:58 AM(UTC)
Parts for Kenmore Freezer 25326452100 - AppliancePartsPros.com
You are probably correct in saying that the control board is resetting when you unplug it.
You could try replacing the control but it is a gamble whether it will fix anything.
Check to be sure that the ground from the line cord is attached to the units frame.
Sumsung refrigerator freezer problem (Refrigerator & Freezer Repair)
by DRJHNJHNSN 4/12/2020 7:59:12 AM(UTC)
Kenmore 21168 freezer problem (Refrigerator & Freezer Repair)
by raski 2/1/2020 10:07:17 AM(UTC)
Freezer Problems (Refrigerator & Freezer Repair)
by CJPolinsky 12/6/2016 4:09:14 PM(UTC)
side by side GE Freezer problem (Refrigerator & Freezer Repair)
by Louise11 10/10/2016 2:28:22 PM(UTC)
GE model PSH25MGTABV freezer problem (Refrigerator & Freezer Repair)
by jwhamby 9/11/2016 5:20:27 PM(UTC)
GE fridge freezer problems (Refrigerator & Freezer Repair)
by robinleigh 2/16/2016 5:33:39 PM(UTC)
GE Bottom freezer problems after main board swap (Refrigerator & Freezer Repair)
by Busy 9/25/2015 9:05:47 AM(UTC)
Hotpoint Fridge/Freezer Problem (Refrigerator & Freezer Repair)
by kateedidnt 6/18/2015 10:59:58 AM(UTC)
25326442100 Kenmore Freezer Problems (Refrigerator & Freezer Repair)
by cover 5/21/2015 6:47:34 PM(UTC)
Upright freezer problem (Refrigerator & Freezer Repair)
by brobriffin 11/20/2014 3:31:42 PM(UTC)
by Bill120 9/2/2014 12:41:21 PM(UTC)
Freezer problems (Refrigerator & Freezer Repair)
by GaryPil 4/21/2014 9:31:00 AM(UTC)
Frigidaire upright freezer problem (Refrigerator & Freezer Repair)
by stephen01 11/19/2013 1:08:44 PM(UTC)
Whirpool Freezer Problems (Refrigerator & Freezer Repair)
by Eds 3rd 9/3/2013 7:34:01 AM(UTC)
Frigidaire refrigerator/freezer problem (Refrigerator & Freezer Repair)
by Mudduck 7/31/2013 2:06:02 PM(UTC)
