no water-ice maker quit producing-i removed icemaker-put hair dyer to rubber line for 5 min-disconnected line at water inlet valve-blew air thru-line is clear. 55 volts at black wire supplying ice maker next day 120 volts at same wire-now is 55 volts. with ice maker still disconnected red optics blinks-when i depress switch-red light is steady on
What is correct troubleshooting from here. Thank you.:)
Originally Posted by: Gene  at step 6 no harvest checked ice maker to center harness and connection is good continued with test and got 3 pulses
continued with test and got 3 pulses 56 volts at black wire
Originally Posted by: sydnoid  56 volts at black wire At what point? Gene.
Originally Posted by: Gene  At what point?
Gene. after testing was completed i disconnected and removed ice maker and checked voltage at center harness where it plugs into icemaker 56 volts thanks
I would recommend to replace the ice maker. Before you'll install the new ice maker, using a flat screwdriver make sure that the slot for the bail arm switch is in On (down) position. Keep in mind that the new ice maker has to be cool down (takes about 12 hours) before producing ice. - The ice maker Part number: 2198597
still 56 volts to ice maker-i jumped pins 3-4 on right side board and with jumper in icemaker it started moving to harvest Does this mean my board is bad because i am not getting 110 volts to the icemaker harness? thanks
Yes, it does. Very likely the problem is with that board even the result of the test is different. If you did order the ice maker from APP then you definitely can return it. - The PC boards kit Part number: 4389102
