My ice maker seems not be getting water. There is water to the dispenser so it is getting to the fridge and through the filter OK. The ice maker cycles normally and I can hear the fill solenoid opening during the cycle, but, no water. Any ideas welcomed. Frozen line behind the ice-maker?
Originally Posted by: tkirsch  My ice maker seems not be getting water. There is water to the dispenser so it is getting to the fridge and through the filter OK. The ice maker cycles normally and I can hear the fill solenoid opening during the cycle, but, no water. Any ideas welcomed. Frozen line behind the ice-maker? T, You're on the right track, Check the water fill tube for ice blockage, Part number: AP3998174
and replace the fill valve, Part number: AP3998174
If the tube is blocked with ice, you'd have a seaping water valve, and will need to replace it. If it's not blocked, but you can hear the valve operate, then there's a failure inside the valve, and you'll need to replace it. :) :) :)
