sydnoid
#1 Posted : 12 years ago
sydnoid
no water-ice maker quit producing-i removed icemaker-put hair dyer to rubber line for 5 min-disconnected line at water inlet valve-blew air thru-line is clear. 55 volts at black wire supplying ice maker next day 120 volts at same wire-now is 55 volts. with ice maker still disconnected red optics blinks-when i depress switch-red light is steady on
What is correct troubleshooting from here. Thank you.:)
#2 Posted : 12 years ago
Perform the troubleshooting as described in the attached file and post the results.
Here are the breakdown diagrams and Parts for Whirlpool KSRX25FNBT01 Refrigerator - AppliancePartsPros.com
File Attachment(s):
In door ice system - component diagnostics.doc (167kb) downloaded 16 time(s).
sydnoid
#3 Posted : 12 years ago
sydnoid
at step 6 no harvest
checked ice maker to center harness and connection is good
continued with test and got 3 pulses
sydnoid
#4 Posted : 12 years ago
sydnoid
56 volts at black wire
#5 Posted : 12 years ago
At what point?
sydnoid
#6 Posted : 12 years ago
sydnoid
At what point?
after testing was completed i disconnected and removed ice maker and checked voltage at center harness where it plugs into icemaker
56 volts
thanks
#7 Posted : 12 years ago
I would recommend to replace the ice maker. Before you'll install the new ice maker, using a flat screwdriver make sure that the slot for the bail arm switch is in On (down) position. Keep in mind that the new ice maker has to be cool down (takes about 12 hours) before producing ice.
- The ice maker Part number: 2198597
sydnoid
#8 Posted : 12 years ago
sydnoid
still 56 volts to ice maker-i jumped pins 3-4 on right side board and with jumper in icemaker it started moving to harvest
Does this mean my board is bad because i am not getting 110 volts to the icemaker harness?
thanks
#9 Posted : 12 years ago
Yes, it does. Very likely the problem is with that board even the result of the test is different.
If you did order the ice maker from APP then you definitely can return it.
- The PC boards kit Part number: 4389102
Guest (4)
Samsung side by side refrigerator No water to ice maker (Refrigerator & Freezer Repair)
by mtrafton 5 years ago
No water to ice maker / water works through door (Refrigerator & Freezer Repair)
by mservice 6 years ago
No water to ice maker or door (Refrigerator & Freezer Repair)
by scar1 6 years ago
No Water To Ice Maker (Refrigerator & Freezer Repair)
by Daussie 8 years ago
by Stone JR 9 years ago
No water dispenses, no water to ice maker (Refrigerator & Freezer Repair)
by jeffreyjd@charter.net 12 years ago
No Water To ice Maker (Refrigerator & Freezer Repair)
by phuluu 13 years ago
by s_pierce 13 years ago
by barbaraann 13 years ago
No water to Ice Maker or Door Unit (Refrigerator & Freezer Repair)
by Kevin933 13 years ago
No Water to Ice Maker or Water Dispenser (Refrigerator & Freezer Repair)
by JoeSavo 14 years ago
by tkirsch 14 years ago
Frigidaire No water to ice maker (Refrigerator & Freezer Repair)
by taberd1985 14 years ago
by pwg02001 14 years ago
Kenmore no water to ice maker. (Refrigerator & Freezer Repair)
by JooeII 14 years ago
