Viki
#1 Posted : Friday, April 20, 2012 9:05:19 AM(UTC)
Viki
No heat in oven when trying to bake or broil. Clock and controls work.
Simon / APP Team
#2 Posted : Friday, April 20, 2012 10:26:41 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you feel Ok to do the "life" test then get access to the control board/clock.
Locate the BK, BRL, L2out contacts at the control.
Set the oven to Bake and using the multimeter check if you have 230VAC between BK and L2out.
Set for broil and check between BRL and L2out.
No 230v - replace the clock.
The control board Part number: 316207511
The overlay Part number: 316220841
Thank you. Good luck. Post the results.
Simon.
Debbie711
#3 Posted : Sunday, October 21, 2012 8:23:57 AM(UTC)
Debbie711
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
Did this exact test and got no reading, so I ordered the control board/clock. Took 10 mins to pop it in and now the stove works like a charm. Thank you!!!
Simon / APP Team
#4 Posted : Monday, October 22, 2012 7:38:47 AM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
Kenmore Range 790.31043803 Control Board iffy (Oven Repair (including Ranges and Cooktops))
by Guest 8/27/2021 2:30:56 PM(UTC)
Kenmore range LED clock will not stay lit (Oven Repair (including Ranges and Cooktops))
by zooeyhall 11/7/2015 5:22:41 PM(UTC)
Kenmore range - control panel works but oven and elements do not (Oven Repair (including Ranges and Cooktops))
by rohag@sbcglobal.net 1/17/2015 7:20:41 AM(UTC)
Kenmore Range Hood - help switching out light knob (Oven Repair (including Ranges and Cooktops))
by cjoplin 8/14/2014 1:55:04 PM(UTC)
door trim on kenmore range (Oven Repair (including Ranges and Cooktops))
by ronandcat 8/10/2014 8:13:51 AM(UTC)
How to replace oven door handle on my Kenmore Range (Oven Repair (including Ranges and Cooktops))
by PaullyK 11/21/2013 10:52:15 AM(UTC)
Broiler comes on for bake setting on Kenmore Range (Oven Repair (including Ranges and Cooktops))
by pbgsho10 11/19/2013 8:09:20 AM(UTC)
Kenmore Range Throwing F10-ERR Code (Oven Repair (including Ranges and Cooktops))
by Mommeeu 7/29/2013 10:04:02 AM(UTC)
Kenmore Range oven handle comes loose, Model 790.94452700 (Oven Repair (including Ranges and Cooktops))
by Turbobob 4/10/2013 11:43:57 AM(UTC)
Kenmore Range oven not working (Oven Repair (including Ranges and Cooktops))
by donnalee 8/19/2012 12:52:46 PM(UTC)
question on Kenmore range (Oven Repair (including Ranges and Cooktops))
by Scott Kn 7/17/2012 12:35:35 PM(UTC)
Kenmore range F40 error code when using self-clean (Oven Repair (including Ranges and Cooktops))
by sahmoffour 3/2/2012 8:21:05 AM(UTC)
Kenmore range - only half of double element works (Oven Repair (including Ranges and Cooktops))
by kc7451 1/15/2012 12:37:30 PM(UTC)
Kenmore Range E2F1 code...please help (Oven Repair (including Ranges and Cooktops))
by tferraro 1/9/2012 7:36:49 AM(UTC)
Kenmore Range flat top burner stays on high (Oven Repair (including Ranges and Cooktops))
by DRW 12/23/2011 4:24:54 AM(UTC)
