rohag@sbcglobal.net
#1 Posted : 10 years ago
rohag@sbcglobal.net
Kenmore electric range - Control panel clock and indicators are working, but oven, broiler or cooktop elements are not responding. Switched breaker off then on again and checked plug. All seem normal.
rohag@sbcglobal.net
#2 Posted : 10 years ago
rohag@sbcglobal.net
All my research pointed towards the power supply. I then discovered a junction box in the basement halfway between the breaker and the stove plug that had 1 of 2 fuses blown which explained why I had enough power for the clock and indicators (110v) but not enough for the oven and stove elements (220v). Replaced fuse, problem solved.
