ellmer
#1 Posted : 13 years ago
ellmer
Washer spins violently like it is out of balance. I have replaced the drive block, clutch, suspension springs, agitator repair kit and transmission. Symptoms still the same. Any ideas?
#2 Posted : 13 years ago
The skate plate under the tub might be out of place, just look at both sides to see if they are not symetric. Also, lift the skate plate and check for missing half round, brown, plastic slides.
ellmer
#3 Posted : 13 years ago
ellmer
Thank you for your prompt and accurate diagnosis of my KitchenAid Washer. Once the skate plate was properly positioned it functions smoothly.:)
#4 Posted : 13 years ago
Thanks for the response. I have fixed a lot of these washers and find it's best to tip the washer back for service, but never lay it down all the way as the skate plate may go out of position once uprighted.
kitchenaid washer kaws800gq1 (Washer Repair)
by maagk 5 years ago
Kitchenaid washer does everything but spin (Washer Repair)
by donohu40 8 years ago
KitchenAid washer stopped spinning (Washer Repair)
by Punisher Bass 10 years ago
need helpplease with trouble shooting kitchenaid washer (Washer Repair)
by lmormsby 11 years ago
Older kitchenaid washer that worked fine and then? (Washer Repair)
by yepyepdude 11 years ago
Kitchenaid washer pulling my hair out! (Washer Repair)
by DANShandy 12 years ago
KitchenAid Washer Weird Issue -Electrical? (Washer Repair)
by zee652 12 years ago
KitchenAid Washer won't drain or spin (Washer Repair)
by MSUMOM 12 years ago
kitchenaid washer won't spin (Washer Repair)
by rdtjr1968 13 years ago
a Kitchenaid washer (Washer Repair)
by wapanstore 13 years ago
kitchenaid washer throwing fault codes (Washer Repair)
by buldog9 13 years ago
by carrisal 14 years ago
KitchenAid Washer (Washer Repair)
by murielh 14 years ago
Kitchenaid washer with very slow agitation (Washer Repair)
by brewer89 14 years ago
