rdtjr1968
#1 Posted : 13 years ago
rdtjr1968
Kitchenaid washer drains fine, but won't spin. Checked the coupler and it's just fine. Removed the cover from the gearcase and restored power to check things out. The spin gear appears to be turning just fine, so put cover back on gearcase but shaft does not turn. Any suggestions?
I was also off a little on the age of the machine. 10-15 years would be more accurate.
#2 Posted : 13 years ago
What is the complete model number of the washer?
rdtjr1968
#3 Posted : 13 years ago
rdtjr1968
model number KAWS677EQ
#4 Posted : 13 years ago
Would it spin if you will open and close the lid while the washer is draining?
If it did, replace the timer.
- The timer Part number: 3950736
Kitchenaid washer won't spin (Washer Repair)
by Fidsters 14 years ago
Kitchenaid Washer won't spin/agitate (Washer Repair)
by sofasurfer 16 years ago
by graciousaint 16 years ago
KitchenAid Washer Won't Spin (Washer Repair)
by frankla10 16 years ago
Help! Kitchenaid washer won't spin or drain (Washer Repair)
by harleygurl 16 years ago
KitchenAid washer won't spin (Washer Repair)
by Sherry 18 years ago
