murielh
#1 Posted : 14 years ago
murielh
Machine's sensor fails to stop at water FILL and water RINSE cycles.
Have to manually move dial. All other cycles work normal.
sidfink43
#2 Posted : 14 years ago
sidfink43
Celan out the tube going from the water level switch to the tub. Watch it operate with the cabinet off. Water should not enter the tube. You can also pull the tube off at the tub level, stick your finger on the tub part to keep water from coming out and blow into the tube. If it does not stop water entering the water level switch is bad.
If all this does not help, try changing out the water level switch.
murielh
#3 Posted : 14 years ago
murielh
Thanks to Sidfink43 for directing me to the water level switch. The clear tubing/hose that connects to the water level switch had fallen off. (most likely happened when moving from house to house)
sidfink43
#4 Posted : 14 years ago
sidfink43
Well good, glad you founhd the problem and did not have to have a service call.
kitchenaid washer kaws800gq1 (Washer Repair)
by maagk 5 years ago
Kitchenaid washer does everything but spin (Washer Repair)
by donohu40 8 years ago
KitchenAid washer stopped spinning (Washer Repair)
by Punisher Bass 10 years ago
need helpplease with trouble shooting kitchenaid washer (Washer Repair)
by lmormsby 11 years ago
Older kitchenaid washer that worked fine and then? (Washer Repair)
by yepyepdude 11 years ago
Kitchenaid washer pulling my hair out! (Washer Repair)
by DANShandy 12 years ago
KitchenAid Washer Weird Issue -Electrical? (Washer Repair)
by zee652 12 years ago
KitchenAid Washer won't drain or spin (Washer Repair)
by MSUMOM 12 years ago
KitchenAid Washer (Washer Repair)
by ellmer 13 years ago
kitchenaid washer won't spin (Washer Repair)
by rdtjr1968 13 years ago
a Kitchenaid washer (Washer Repair)
by wapanstore 13 years ago
kitchenaid washer throwing fault codes (Washer Repair)
by buldog9 13 years ago
by carrisal 13 years ago
by carrisal 14 years ago
Kitchenaid washer with very slow agitation (Washer Repair)
by brewer89 14 years ago
