3 Pages<123>
#11 Posted : Monday, August 20, 2012 3:20:27 PM(UTC)
You are welcome. I'm glad it was nothing wrong with the oven.
cboneill
#12 Posted : Tuesday, September 25, 2012 1:14:35 AM(UTC)
cboneill
Does the Whirlpool RBD245PDT15 have either the Control Panel Thermal Fuse or Shut Down Thermal Fuse?
"E6 F2" displayed for about 8 minutes followed by beep (_ _ . . . ).
#13 Posted : Tuesday, September 25, 2012 12:28:00 PM(UTC)
Yes, it does have such fuses. What exactly is wrong with the oven?
Here are the breakdown diagrams and Replacement parts for Whirlpool RBD245PDT15 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER | AppliancePartsPros.com
cboneill
#14 Posted : Tuesday, September 25, 2012 1:06:03 PM(UTC)
cboneill
Display is black and will occasionally display "E6 F2" for about 8 minutes followed by beep (_ _ . . . ). I opened up the top section and located the fuse.
#15 Posted : Tuesday, September 25, 2012 2:12:21 PM(UTC)
If it does display the error code occasionally then it has nothing to do with the control panel fuse. More likely the problem is a bad control board.
- The control board Part number: W10406070
cboneill
#16 Posted : Tuesday, September 25, 2012 5:18:06 PM(UTC)
cboneill
YIPES! I was whining about the $185.00 for a Control Panel and now it's up to $386.00. I removed the Control Panel and cleaned the ribbon cable with an eraser. After reconnecting the cable the panel lights came on and I was able to set the clock. While I was securing the panel, the display went dark again. Please tell me there's a chance I can still either fix the problem or a Control Panel will correct what ails it. Retirement income ain't ready for a $400.00 outlay (Whirlpool Cooktop infinite switch went out, too).
cboneill
#17 Posted : Tuesday, September 25, 2012 6:41:33 PM(UTC)
cboneill
All of the Solutions associated with my Fault Code, E6-F2 (Cancel key drive line open) seem to point toward the Keypad.
cboneill
#18 Posted : Thursday, September 27, 2012 12:00:39 PM(UTC)
cboneill
Talked to someone at Appliance Parts Pro who asked some tech guys if there was a way to determine if the problem with my RBD245PDT15 oven was with the Control Board or Control Panel (keypad). I was advised to
1) turn off power to oven,
2) unplug keypad ribbon cable at Control Board,
3) turn on power to oven to see if original fault codes (E6-F2) reappeared on Control Board display.
During the first hour that power was on oven, fault code "E1-F2" appeared to advise me that the "keypad cable was unplugged". I ordered a replacement Control Panel Assembly that I can return if this test didn't correctly identify the problem. Thanks for your assistance.
#19 Posted : Thursday, September 27, 2012 12:06:58 PM(UTC)
Originally Posted by: cboneill Go to Quoted Post
...While I was securing the panel, the display went dark again...
I'm afraid it has nothing to do with the control panel.
cliffthewoodman
#20 Posted : Friday, October 19, 2012 8:21:15 AM(UTC)
cliffthewoodman
it appears that the replacement part has 1/4" female spade on one side & 3/16" female spade on the other. as i have to replace mine that has 1/4" on both sides, whic side goes to the control panel
Guest (5)
3 Pages<123>
