You are welcome. I'm glad it was nothing wrong with the oven.
Does the Whirlpool RBD245PDT15 have either the Control Panel Thermal Fuse or Shut Down Thermal Fuse? "E6 F2" displayed for about 8 minutes followed by beep (_ _ . . . ).
Display is black and will occasionally display "E6 F2" for about 8 minutes followed by beep (_ _ . . . ). I opened up the top section and located the fuse.
If it does display the error code occasionally then it has nothing to do with the control panel fuse. More likely the problem is a bad control board. - The control board Part number: W10406070
YIPES! I was whining about the $185.00 for a Control Panel and now it's up to $386.00. I removed the Control Panel and cleaned the ribbon cable with an eraser. After reconnecting the cable the panel lights came on and I was able to set the clock. While I was securing the panel, the display went dark again. Please tell me there's a chance I can still either fix the problem or a Control Panel will correct what ails it. Retirement income ain't ready for a $400.00 outlay (Whirlpool Cooktop infinite switch went out, too).
All of the Solutions associated with my Fault Code, E6-F2 (Cancel key drive line open) seem to point toward the Keypad.
Originally Posted by: Gene  If it does display the error code occasionally then it has nothing to do with the control panel fuse. More likely the problem is a bad control board. - The control board Part number: W10406070
Gene. Talked to someone at Appliance Parts Pro who asked some tech guys if there was a way to determine if the problem with my RBD245PDT15 oven was with the Control Board or Control Panel (keypad). I was advised to 1) turn off power to oven, 2) unplug keypad ribbon cable at Control Board, 3) turn on power to oven to see if original fault codes (E6-F2) reappeared on Control Board display. During the first hour that power was on oven, fault code "E1-F2" appeared to advise me that the "keypad cable was unplugged". I ordered a replacement Control Panel Assembly that I can return if this test didn't correctly identify the problem. Thanks for your assistance.
Originally Posted by: cboneill  ...While I was securing the panel, the display went dark again... I'm afraid it has nothing to do with the control panel. Gene.
it appears that the replacement part has 1/4" female spade on one side & 3/16" female spade on the other. as i have to replace mine that has 1/4" on both sides, whic side goes to the control panel
