Should I also swap pots while I am at it?
No signs of any issues on the disassembled pot. All traces look bright and shiny. The contacts also are bright and shiny.
I did swap the pots, and that didn't change things. Moving on...
Testing per the procedure
1. Voltage from Spark Module a. SW1-N: 366mV with burner on HI b. SW2-N: 121.3V with burning on HI c. NO A on my spark module
2. Voltages at Simmer Controller Some issues here as mine is not labeled like the instructions... I have a Line and -5V contact (I believe these are ganged together). a. POT2-Line: 0VDC with burner on high b. POT2 to -5V: 0VDC with burner on high c. POT1-Line: 0VDC with burner on high d. POT1 to -5V: 0VDC with burner on high
3. Check voltage from Line5 to Line. a. 0 VDC
Replace simmer controller??? We did that...
Originally Posted by: stevehanna
...I connected the line from the rear to the known good pot/valve- the breaker tripped immediately when I reconnected power (pot in off position). "Pop" and ozone. So generally un-good stuff...
It is possible that the simmer control got damaged due to this electrical short. Gene.
Anything else you would recommend trying or testing before ordering a replacement?
Not much what I can see.
Thanks Gene. WIll update when I have the part.
Is there a PN for the rubber feet that go on the burner grates? As long as I am ordering I would love to get those too.
Looks like they are coming together with the grates only.
