5 Pages«<345
stevehanna
#41 Posted : Monday, September 24, 2012 11:24:02 AM(UTC)
stevehanna
Should I also swap pots while I am at it?
stevehanna
#42 Posted : Monday, September 24, 2012 12:49:44 PM(UTC)
stevehanna
No signs of any issues on the disassembled pot. All traces look bright and shiny. The contacts also are bright and shiny.
stevehanna
#43 Posted : Monday, September 24, 2012 2:10:00 PM(UTC)
stevehanna
I did swap the pots, and that didn't change things. Moving on...
Testing per the procedure
1. Voltage from Spark Module
a. SW1-N: 366mV with burner on HI
b. SW2-N: 121.3V with burning on HI
c. NO A on my spark module
2. Voltages at Simmer Controller
Some issues here as mine is not labeled like the instructions... I have a Line and -5V contact (I believe these are ganged together).
a. POT2-Line: 0VDC with burner on high
b. POT2 to -5V: 0VDC with burner on high
c. POT1-Line: 0VDC with burner on high
d. POT1 to -5V: 0VDC with burner on high
3. Check voltage from Line5 to Line.
a. 0 VDC
Replace simmer controller??? We did that...
#44 Posted : Monday, September 24, 2012 2:24:03 PM(UTC)
Originally Posted by: stevehanna Go to Quoted Post
...I connected the line from the rear to the known good pot/valve- the breaker tripped immediately when I reconnected power (pot in off position). "Pop" and ozone. So generally un-good stuff...
It is possible that the simmer control got damaged due to this electrical short.
stevehanna
#45 Posted : Monday, September 24, 2012 4:26:59 PM(UTC)
stevehanna
Anything else you would recommend trying or testing before ordering a replacement?
#46 Posted : Monday, September 24, 2012 4:52:49 PM(UTC)
Not much what I can see.
stevehanna
#47 Posted : Tuesday, September 25, 2012 9:42:35 AM(UTC)
stevehanna
Thanks Gene. WIll update when I have the part.
Is there a PN for the rubber feet that go on the burner grates? As long as I am ordering I would love to get those too.
#48 Posted : Tuesday, September 25, 2012 11:52:32 AM(UTC)
Looks like they are coming together with the grates only.
5 Pages«<345
