flyin34
#1 Posted : Thursday, September 13, 2012 10:52:05 AM(UTC)
flyin34
First the ice quit dispensing, I think I have figured out the problem to that as the drive shaft for the auger looks stripped. I am going to order that part. But now the ice maker quit making ice. The front water dispenser is working and from what I can tell the water supply to the ice maker isn't clogged. When I push in the lever on the left for the infrared the red light is solid and when I let it out the red light blinks twice. What should I check next? Thanks
flyin34
#2 Posted : Friday, September 14, 2012 7:04:38 AM(UTC)
flyin34
Anyone????
Simon / APP Team
#3 Posted : Friday, September 14, 2012 10:29:57 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
To check if this is the icemaker or the water valve switch around the solenoid plugs at the water valve and push the water dispenser lever.
If the icemaker starts filling up - then it's a bad icemaker.
The water valve Part number: W10408179
The icemaker Part number: 2198597
Here are the breakdown diagrams and Replacement parts for Whirlpool KSRG25FTST01 REFRIGERATOR | AppliancePartsPros.com
Post the results.
Si9mon.
flyin34
#4 Posted : Saturday, September 15, 2012 4:10:07 PM(UTC)
flyin34
Not sure what u want me to check at the water valve by your post. And where is the water lever? Thanks
Simon / APP Team
#5 Posted : Monday, September 17, 2012 10:49:33 AM(UTC)
Simon / APP Team
Groups: APP Team
Have you looked at the water valve? There are 2 solenoids with the disconnect plugs. Switch this plugs around.
The water lever is what you press to start the water in the dispenser.
Simon.
flyin34
#6 Posted : Thursday, September 20, 2012 7:17:15 AM(UTC)
flyin34
Ok gotcha. Yeah cause the line to the water dispenser has water in it but the line to the ice maker is dry...Ill will switch them around tomorrow and see what happens. Thanks
flyin34
#7 Posted : Thursday, September 20, 2012 7:39:46 AM(UTC)
flyin34
Should I be concerned with the infrared light? Should it be blinking, staying on??
flyin34
#8 Posted : Monday, September 24, 2012 10:17:49 AM(UTC)
flyin34
Ok Simon, I did switch the leads on the water valve and when I push the water lever the ice maker does fill up. So is there anything else I need to check? Or is it 100% the icemaker before I go ahead and order an icemaker?
Simon / APP Team
#9 Posted : Tuesday, September 25, 2012 7:51:11 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Sorry couldn't get back earlier. You should go ahead and replace the icemaker.
Post the results.
Simon.
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 9/27/2022 12:38:23 PM(UTC)
Sub-zero ice maker not working - water line? (Refrigerator & Freezer Repair)
by doingthebestican 4/28/2021 11:44:07 AM(UTC)
Samsung RF267 fridge ice maker not working (Refrigerator & Freezer Repair)
by splumer 4/8/2021 11:13:45 AM(UTC)
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 12/11/2020 4:23:17 PM(UTC)
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 11/14/2020 10:28:34 AM(UTC)
GE Mother Board Replacement - Ice Maker Not Working (Refrigerator & Freezer Repair)
by oneijack 4/20/2020 7:26:54 PM(UTC)
Maytag WRX735SDHZ00 Ice Maker not working (Refrigerator & Freezer Repair)
by mp1975 11/9/2019 3:32:25 PM(UTC)
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 10/19/2019 2:18:49 PM(UTC)
GE Artica ice maker not working (Refrigerator & Freezer Repair)
by gr8filed 9/28/2019 4:41:03 AM(UTC)
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 6/26/2018 11:54:43 AM(UTC)
Ice maker not working (Refrigerator & Freezer Repair)
by Stuckbad 9/17/2017 11:20:17 AM(UTC)
Ice Maker not working after replacing several parts (Refrigerator & Freezer Repair)
by Rylos 9/9/2017 12:46:10 PM(UTC)
frigidaire ffss2614qs0 ice maker not working but dispenses water (Refrigerator & Freezer Repair)
by whstrain 7/29/2017 8:42:47 AM(UTC)
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 7/21/2017 9:34:37 AM(UTC)
