First the ice quit dispensing, I think I have figured out the problem to that as the drive shaft for the auger looks stripped. I am going to order that part. But now the ice maker quit making ice. The front water dispenser is working and from what I can tell the water supply to the ice maker isn't clogged. When I push in the lever on the left for the infrared the red light is solid and when I let it out the red light blinks twice. What should I check next? Thanks
Groups: APP Team
Hi. To check if this is the icemaker or the water valve switch around the solenoid plugs at the water valve and push the water dispenser lever. If the icemaker starts filling up - then it's a bad icemaker. The water valve Part number: W10408179
Not sure what u want me to check at the water valve by your post. And where is the water lever? Thanks
Groups: APP Team
Have you looked at the water valve? There are 2 solenoids with the disconnect plugs. Switch this plugs around. The water lever is what you press to start the water in the dispenser.
Simon.
Ok gotcha. Yeah cause the line to the water dispenser has water in it but the line to the ice maker is dry...Ill will switch them around tomorrow and see what happens. Thanks
Should I be concerned with the infrared light? Should it be blinking, staying on??
Ok Simon, I did switch the leads on the water valve and when I push the water lever the ice maker does fill up. So is there anything else I need to check? Or is it 100% the icemaker before I go ahead and order an icemaker?
Groups: APP Team
Hi.
Sorry couldn't get back earlier. You should go ahead and replace the icemaker.
Post the results.
Simon.
