RobbieRob4ya
#1 Posted : Friday, September 7, 2012 9:43:36 AM(UTC)
RobbieRob4ya
Hello All,
My washer will agitate and drain but the tub wont spin during the spin cylce. I just replaced the clutch assembly but that didnt fix the issue. Could the issue be the washer drive block?
sidfink43
#2 Posted : Monday, September 10, 2012 11:36:59 AM(UTC)
sidfink43
Check and make sure the brakes are releasing, and also that the clutch is turning during the spin cycle.
If so, then yes, the drive block could be the problem.
RobbieRob4ya
#3 Posted : Tuesday, September 11, 2012 10:16:59 AM(UTC)
RobbieRob4ya
Are there any videos out there that i can look at to check the clutch and brakes? I have no clue how to do either.
RobbieRob4ya
#4 Posted : Tuesday, September 11, 2012 10:38:31 AM(UTC)
RobbieRob4ya
I think I figured out how to check the clutch by simply tilting the machine backwards. I don’t see the clutch spinning at all. That’s if the entire cylinder is supposed to spin.
sidfink43
#5 Posted : Tuesday, September 11, 2012 12:27:46 PM(UTC)
sidfink43
Okay, if it still agitates then that suggests a transmission issue. You should see the clutch housing moving. But first check to see that the new clutch is installed correctly.
Guest (4)
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
washer wont spin (Washer Repair)
by allen9258 4/8/2018 11:08:33 PM(UTC)
Maytag Bravos Washer wont spin (Washer Repair)
by utzzy27 10/2/2016 1:15:15 PM(UTC)
washer wont spin out (Washer Repair)
by dokratt 4/16/2016 2:50:25 PM(UTC)
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 11/17/2015 12:56:58 PM(UTC)
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
by Denarae 8/4/2015 7:21:30 AM(UTC)
Frigidaire Washer Wont spin high speed (Washer Repair)
by jchi2210 12/17/2014 12:01:09 PM(UTC)
washer wont spin& drain (Washer Repair)
by aristeoherrera@gmail.com 12/10/2014 3:19:57 PM(UTC)
by lvest 7/26/2014 11:09:50 AM(UTC)
by Mattbri 5/30/2014 11:16:21 AM(UTC)
ge profile washer wont spin (Washer Repair)
by ron1821 3/24/2014 4:57:26 PM(UTC)
GE profile washer wont spin (Washer Repair)
by ron1821 3/19/2014 11:31:36 AM(UTC)
Maytag washer wont spin, smoking from under and smells like burnt rubber (Washer Repair)
by trytodiy 3/13/2014 6:20:43 PM(UTC)
