Sometime when cooking the oven randomly will shut off. Usually after 15 minutes or more. The display panel remains on but the cooking mode shuts down. This happens most frequently when we open the oven to check on the item cooking than close the door.
Would appreciate any ides.
Groups: APP Team
I replaced part number AP3851310 which I believe is the display but seems to also be referred to as a control board, about a year and a half ago. Is this the part you suggest I replace. Also do they normally go bad this often? Thanks for your help Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif)
Originally Posted by: richwest41 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...I replaced part number AP3851310 which I believe is the display but seems to also be referred to as a control board, about a year and a half ago... What was the problem at that time? Sounds like this part failed again. Quote:...Also do they normally go bad this often?... Normally any part should last much longer but... Gene.
The last time I had problems the oven would beep and the unit would stop cooking. We would have to shut it down at the circuit box and reset it numerous times to get it to go back on again. Also, on some occasions we would get an F-24 error code.
It looks to me like the same part failure.
