29 Pages«<2021222324>»
bonasera2
#211 Posted : Thursday, August 30, 2012 5:16:31 PM(UTC)
bonasera2
What exactly is wrong with your oven?
Here are the breakdown diagrams and Replacement parts for Whirlpool RBD245PDB10 ELECTRIC OVEN | AppliancePartsPros.com
It initially had the E6 F2 error code with about 9 audible beeps. It now has no lights on the display and the only item that works is the interior oven light whether by the touch pad or opening the door. Nothing else is functional and the display is black. Intermittently, the approx 9 rapid, audible beeps will sound but nothing else. Thanks.
#212 Posted : Tuesday, September 4, 2012 6:32:35 PM(UTC)
Most likely the problem is a bad control board. Unfortunately the part has been discontinued and is no longer available. Looks like it's time for a new oven unless you can find some place where it can be rebuild. The part number for the control board is 8302967.
Doc Holliday
#213 Posted : Saturday, September 15, 2012 5:47:55 PM(UTC)
Doc Holliday
Doc,
If the display is blank and this is not the transformer then the control board has gone bad. Unfortunately this part has been discontinued. Looks like it's time for a new oven. Sorry for that bad news but it could be a good news for your wife. Lol.
Good news! Sent my control board to ************************.com and they were able to repair it. And at about 20% of the cost of a new oven. Funny, the repairs carry a two year warranty while a new control panel, when they were available, only had a year warranty.
Doc
Doc Holliday
#214 Posted : Sunday, September 16, 2012 8:48:34 AM(UTC)
Doc Holliday
Doc
Sorry about the fopaa regarding my naming the website.
Doc Holliday
#215 Posted : Monday, September 17, 2012 5:49:59 PM(UTC)
Doc Holliday
OK, so the cavity programming instructions read like an Apollo 13 sequence and include a "Cancel" button. Problem is, there is no such button on my oven. Anybody know which button is the "cancel" button?
Thanks,
Doc
#216 Posted : Tuesday, September 18, 2012 3:42:29 PM(UTC)
Hi Doc,
Try to use the "upper off" button instead of "cancel".
amazingrace
#217 Posted : Monday, September 24, 2012 2:46:26 PM(UTC)
amazingrace
So I have the same error code...E6, F2 that everyone else has been getting. Ordered the panel and assembly parts (I believe those are the names) and it worked fine for a few days. Now I went to start the oven and many buttons will not press...like the start button. My ovens are RDB245PDQ14. I would appreciate any help
Carrie
#218 Posted : Monday, September 24, 2012 2:54:40 PM(UTC)
Hi Carrie,
What are the part numbers of the part you replaced?
Here are the breakdown diagrams and Replacement parts for Whirlpool RBD245PDQ14 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER | AppliancePartsPros.com
amazingrace
#219 Posted : Monday, September 24, 2012 3:38:17 PM(UTC)
amazingrace
AP5272198 (W10406070) and AP3046697 (8300428)
Carrie
#220 Posted : Monday, September 24, 2012 5:06:20 PM(UTC)
Open the control panel and check the ribbon cable connection to the control board. Make sure it's plugged in all the way.
Guest (10)
Whirlpool fault code E6 F2 (Oven Repair (including Ranges and Cooktops))
by msdabbert 11/26/2009 8:21:35 PM(UTC)
