29 Pages«<272829
safletcher
#281 Posted : Wednesday, January 10, 2018 7:20:01 PM(UTC)
safletcher
I had my control board refurbished and installed it tonight. Upon turning the power back on, the unit goes into a pattern of seven short beeps followed by a brief pause. I tried the key sequence for programming the board for the correct oven cavity, but that isn't working. The oven goes into "timed cook" mode and reverts back to beeping after I cancel. Any ideas?
#282 Posted : Thursday, January 11, 2018 11:06:15 PM(UTC)
Originally Posted by: safletcher Go to Quoted Post
I had my control board refurbished...
Who did it?
Double check the wire harness and touchpad connections. If they fine, the control board is bad.
safletcher
#283 Posted : Friday, January 12, 2018 3:24:46 AM(UTC)
safletcher
Fix Your Board did the refurb.
I cleaned the ribbon connecting the touchpad to the control board. The beeping stopped and we got an E1F2 error code. Replacing the keypad now...
Viejoaz
#284 Posted : Monday, June 29, 2020 3:24:28 PM(UTC)
Viejoaz
United States
Whirlpool range/oven
Slide in 4.8 touch control ss.
No power, control panel dead. 3 3 Months after purchase c.panel would go dead. 2-3 hours back on. After 2nd occurrence, service replaced control board.
Now c.panel dead for 48 hours. Circuit breaker reset, 200 v at wall outlet and unit terminal block.
Guest (12)
Whirlpool fault code E6 F2 (Oven Repair (including Ranges and Cooktops))
by msdabbert 11/26/2009 8:21:35 PM(UTC)
29 Pages«<272829
