When turning the start knob it just buzzes and will not start. What could the issue be?
Groups: APP Team
Hi. Tape the door switch in, set the timer and with one hand start the dryer while with another one turn the drum. If the dryer starts - replace the motor. If not - check the belt and the belt switch. The switch Part number: WE04X10096
