rjlucio
#1 Posted : Tuesday, August 21, 2012 1:34:15 PM(UTC)
rjlucio
My Roper dryer is not heating. Air flow seems normal, drum is tumbling, I replaced the heating element, what else can it be?
Simon / APP Team
#2 Posted : Tuesday, August 21, 2012 1:58:09 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
First of all check if you are getting 240VAC to the dryer.
Then with dryer unplugged check the continuity of the thermal cut-off and the hi-limit thermostats above the heater contacts.(Take one wire off when testing).
The thermal cut-off kit Part number: 279816
Part number: 279816
Another test is to jump the timer's contacts BK and R. If the heater comes on - replace the timer Part number: W10185972
Post the results.
Simon.
rjlucio
#3 Posted : Thursday, August 23, 2012 3:27:30 PM(UTC)
rjlucio
I have now replaced the heating element and the thermal cut off kit. Everything on the dryer is working, but still no heat. This was not an expensive dryer, so unless there are a couple of inexpensive parts that I can put on this thing, it is actually going to be cheaper for me to just go buy a new one....any suggestions???
Simon / APP Team
#4 Posted : Friday, August 24, 2012 10:17:50 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Have you done any tests I suggested before replacing parts?
Simon.
roper dryer not heating (Dryer Repair)
by JONCNC1976 1/6/2015 7:05:49 AM(UTC)
Roper dryer not heating and timer not advancing (Dryer Repair)
by kennethgore 12/2/2013 7:09:15 AM(UTC)
Roper dryer not heating or turning off (Dryer Repair)
by kb1021 3/27/2012 4:10:20 PM(UTC)
roper dryer not heating up help (Dryer Repair)
by heather608 3/18/2011 5:01:11 PM(UTC)
Roper Dryer Not Heating (Dryer Repair)
by SMITHE 11/11/2009 10:47:01 AM(UTC)
