SMITHE
#1 Posted : Wednesday, November 11, 2009 10:47:01 AM(UTC)
SMITHE
I think the dryer cycling t-stat may be bad. I have voltage at the top and bottom of the swith, but not on the sides ( violet wires). Would jumping these wires make the dryer heat? Everything else seems to checkout. I did notice that I only have 120v across the element. Would this t-stat have an effect on that?
Qtip
#2 Posted : Wednesday, November 11, 2009 8:21:28 PM(UTC)
Qtip
Dryer will run with 120. needs full 240 for heater to work. flip the breaker and re-test for 240. after flipping the breaker you should get the full 240 unless the inner wires of the outlet burned up (unlikely but possible). usually a power surge or outage will cause half the line to trip so try flipping the breaker and that will probably fix your problem
#3 Posted : Thursday, November 12, 2009 6:03:56 AM(UTC)
Replacement parts for WHIRLPOOL REX4634KQ0 | AppliancePartsPros.com
Here is your wiring diagram
http://www.servicematters.com/d...0Sheet%20-%203406688.pdf
Do not jump these wires they are the internal heater and you will put a dead short across 120 volts.
If you have 240 volts across the operating thermostat's contacts at room temperature then it is bad. It should be 0 volts.
If you have a true 120 volts across the heating element it should be heating up, though at half the watts of it's normal operation.
PS: Just a thought, why your are testing with the unit plugged in and risking a shock, burn or worse when the heating circuit can usually be checked with the unit unplugged using resistance.
roper dryer not heating (Dryer Repair)
by JONCNC1976 1/6/2015 7:05:49 AM(UTC)
Roper dryer not heating and timer not advancing (Dryer Repair)
by kennethgore 12/2/2013 7:09:15 AM(UTC)
Roper Dryer Not Heating (Dryer Repair)
by rjlucio 8/21/2012 1:34:15 PM(UTC)
Roper dryer not heating or turning off (Dryer Repair)
by kb1021 3/27/2012 4:10:20 PM(UTC)
roper dryer not heating up help (Dryer Repair)
by heather608 3/18/2011 5:01:11 PM(UTC)
