Replacement parts for Roper REX3519PQ0 29" ELECTRIC DRYER | AppliancePartsPros.comSee the attachment for the wiring diagram.
You did not say what cycle type you were running.
If it was an auto cycle try a timed dry cycle.
Does the timer advance now?
If not then odds are that you have an electrical problem with the 240 volts as the heating coil and the timer run off of the 240.
Try flipping the breaker off/on slowly a couple times.
If that does nothing I would check the power.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!![/COLOR]
If the timer advances in timed dry but not auto then odds are the problem is with the heater circuit. In timed dry the timer motor gets power directly from the line (240 volts) but in auto modes it gets power through the heating element when the element shuts off.
Unplug the unit and both wires to the heating coil.
Check the coil with a meter should be 8 to 12 ohms.
If open replace it.
Also check the hi-limit thermostat and thermal cut-off, both should be 0 ohms.
The reason for this is that you were having long dry times and the heating coil may have grounded out and has finally burned out.
This puts only 120 volts on the heater so you can get low heat all the time but it can also blow the high limit and/or thermal cut-off.
It would also be a good time to check/clean you vent system.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
