kb1021
#1 Posted : Tuesday, March 27, 2012 4:10:20 PM(UTC)
kb1021
Last night I started a load of laundry in my dryer and 2 hours later realized that it was still running and the nob hadn't moved at all. I opened the door and my clothes had been tumbling, but it wasn't warm at all. I've noticed over the past couple of weeks that I was having to run clothes through twice before my clothes would dry completely. What could this possibly be? :confused: Thanks for the advice in advance!
Simon / APP Team
#2 Posted : Tuesday, March 27, 2012 5:00:35 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Need a bit more info.
How do you stop the dryer? Advance the timer to off, will it stop? Open the door, will it stop?
Please post the results.
kb1021
#3 Posted : Tuesday, March 27, 2012 5:40:08 PM(UTC)
kb1021
I can stop it, but I would have to turn the nob or open the door to make it stop.
Simon / APP Team
#4 Posted : Tuesday, March 27, 2012 7:01:56 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you are OK to run the "live" test, open the control panel, turn the dryer on and check for 120v at the timer contacts BK to TM.
If you read 120v - replace the timer.
The timer Part number: AP3131254
Here are the breakdown diagrams and Replacement parts for Roper REX3519PQ0 29" ELECTRIC DRYER | AppliancePartsPros.com
Thank you. Post the results.
#5 Posted : Wednesday, March 28, 2012 3:07:38 AM(UTC)
See the attachment for the wiring diagram.
You did not say what cycle type you were running.
If it was an auto cycle try a timed dry cycle.
Does the timer advance now?
If not then odds are that you have an electrical problem with the 240 volts as the heating coil and the timer run off of the 240.
Try flipping the breaker off/on slowly a couple times.
If that does nothing I would check the power.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If the timer advances in timed dry but not auto then odds are the problem is with the heater circuit. In timed dry the timer motor gets power directly from the line (240 volts) but in auto modes it gets power through the heating element when the element shuts off.
Unplug the unit and both wires to the heating coil.
Check the coil with a meter should be 8 to 12 ohms.
If open replace it.
Also check the hi-limit thermostat and thermal cut-off, both should be 0 ohms.
The reason for this is that you were having long dry times and the heating coil may have grounded out and has finally burned out.
This puts only 120 volts on the heater so you can get low heat all the time but it can also blow the high limit and/or thermal cut-off.
It would also be a good time to check/clean you vent system.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
#6 Posted : Wednesday, March 28, 2012 3:11:06 AM(UTC)
For some unknown reason the wiring diagram did not attach so here it is, I hope.
I still cannot attach it so here is a link to an earlier post that includes the wiring diagram.
http://forum.appliancepartspros...tml?highlight=rex3519%2A
kb1021
#7 Posted : Wednesday, March 28, 2012 4:21:37 AM(UTC)
kb1021
I just tried using it on timed try and the nob advances. It just doesnt advance is auto sense mode. I would guess that this means my issue is a heating problem?
#8 Posted : Wednesday, March 28, 2012 4:33:59 AM(UTC)
[COLOR="DarkRed"]I would guess that this means my issue is a heating problem?[/COLOR]
Yes, odds are that your heating element is blown.
