pedrovideo
#1 Posted : Wednesday, August 15, 2012 7:48:45 PM(UTC)
pedrovideo
I check the continuity operating thermostat and bias heater and it was opened. I replaced it. dryer worked for an hour with heat then stopped working. i replaced operating thermostat and bias heater and it failed again this no heat at all. check heater element and the two thermostat attached to housing and they check fine. Should i replace everything? something is shorting it out. any suggestions?
#2 Posted : Friday, August 17, 2012 2:24:54 AM(UTC)
Replacement parts for Kenmore 11064982301 | AppliancePartsPros.com
Sorry but I am confused.
I looked up your unit on AppliancePartsPros and at the Sears parts site and the given model does not use an operating thermostat and bias heater.
It uses a thermistor and electronic control.
Please check your model number.
See the attachment for the tech sheet for the model number you gave.
File Attachment(s):
64982301.pdf (390kb) downloaded 6 time(s).
pedrovideo
#3 Posted : Monday, August 20, 2012 3:38:36 PM(UTC)
pedrovideo
thanks for your help and the service pdf. Its was a great help. You are right its call a thermistor. It looks like my problem is the electronic control assembly according to manual since everything else is fine. could it be anything else?
#4 Posted : Tuesday, August 21, 2012 2:11:58 AM(UTC)
I cannot say as I do not know how you checked the other parts to ensure they are OK.
One thing a lot of people miss is checking the power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Also I think that the motor and the heater relays on this unit are the same but double check just to be sure.
If they are then you can swap them. If now the unit will not run, replace the relay.
Samsung dryer wont heat (Dryer Repair)
by Dabenthall 12/19/2016 10:51:29 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
by bennieman 11/9/2016 10:30:17 AM(UTC)
by mkrason 12/18/2015 3:28:25 PM(UTC)
Maytag Dryer wont heat (Dryer Repair)
by Rescal 8/18/2015 5:23:15 PM(UTC)
by highcountry71 8/16/2015 8:42:56 AM(UTC)
Kenmore 80 Series...Dryer Wont Heat... Tested/continuity good (Dryer Repair)
by xtacbyme 6/3/2015 7:57:15 PM(UTC)
dryer wont heat in timed dry mode (Dryer Repair)
by thildy 5/7/2015 2:26:44 PM(UTC)
by Jim Winkels 4/5/2015 5:08:25 PM(UTC)
Whirlpool dryer wont heat (Dryer Repair)
by ekujustice 4/2/2015 4:47:16 PM(UTC)
Dryer wont heat on timed dry and works sometimes on auto setting (Dryer Repair)
by AJM57 3/14/2015 8:45:13 AM(UTC)
by Nmiles 11/24/2014 2:22:06 PM(UTC)
electric dryer wont heat (Dryer Repair)
by janietodd 9/24/2014 11:10:25 AM(UTC)
ge dryer wont heat (Dryer Repair)
by appliancerepairguy 9/13/2014 11:31:54 PM(UTC)
Dryer wont heat - element and fuses/limiters fine (Dryer Repair)
by watsonwabbit69 6/19/2014 10:41:14 AM(UTC)
