oldndn
#1 Posted : Sunday, April 5, 2009 11:50:21 AM(UTC)
oldndn
We are getting power from the outlet to the back of the dryer,but from there to the start switch we have no power.
#2 Posted : Monday, April 6, 2009 4:10:24 AM(UTC)
Replacement parts for GE NVL333EB4CC | AppliancePartsPros.com
When you say you have power did you check it with a meter.
You must check L1 to L2 = 240 volts and L1 to Neutral & L2 to Neutral = 120 volts. Motor uses 120 volts and it is not unusual for you to loose half the line without actually tripping the breaker.
Not sure where you measured so cannot comment on this.
I do not have a wiring diagram for this unit so am doing some guessing.
Your unit may have the thermal limiter Item 1236 in "Cabinet & drum" section wired is series with the start switch or if it is in the motor circuit it will still give an apparent no power symptom..
Also the door switch is usually ahead of the start switch in the circuit.
If you do not have the wiring diagram take a look in the control console, they like to hide them in there.
Hotpoint dryer schematic HT21EASKOWW (Dryer Repair)
by BigHoward 9/16/2020 7:40:14 PM(UTC)
Hotpoint dryer doesn't stay running (Dryer Repair)
by mvask193 7/16/2015 5:47:39 PM(UTC)
Hotpoint dryer's button just buzzes-only 2 yrs. old (Dryer Repair)
by Zappy912 6/23/2015 11:45:05 PM(UTC)
Hotpoint Dryer blew hole in back panel (Dryer Repair)
by Cooprr 4/29/2015 3:17:40 PM(UTC)
Hotpoint dryer electrical schematic (Dryer Repair)
by teppler 3/10/2014 8:42:20 AM(UTC)
Hotpoint Dryer Ignitor Does Not Glow (Dryer Repair)
by michaelb 12/24/2013 12:58:35 PM(UTC)
Hotpoint Dryer (Dryer Repair)
by wren200 8/27/2012 10:25:58 AM(UTC)
Hotpoint Dryer is driving me insane. (Dryer Repair)
by OldPete 8/14/2012 3:38:37 PM(UTC)
& Year Old Hotpoint Dryer Works on 1 Cycle and don't shut off (Dryer Repair)
by wyocwboy 8/3/2012 5:29:00 AM(UTC)
Hotpoint dryer needs drum pushed in order to start (Dryer Repair)
by Mecklenburg 7/26/2012 12:23:50 PM(UTC)
Squeaky hotpoint dryer. (Dryer Repair)
by Eckto 4/11/2012 12:30:17 PM(UTC)
Hotpoint Dryer Motor (Dryer Repair)
by mcchapman01 11/28/2010 3:04:24 AM(UTC)
Busted Hotpoint Dryer (Dryer Repair)
by jonnyb8390 8/31/2010 4:07:27 PM(UTC)
Hotpoint dryer randomly makes noises (Dryer Repair)
by galleyhand 2/8/2010 3:18:35 PM(UTC)
hotpoint dryer (Dryer Repair)
by ajcarver 2/2/2010 6:48:56 AM(UTC)
