CSteidl
#1 Posted : Tuesday, August 14, 2012 11:59:05 AM(UTC)
CSteidl
I did some work on this dryer a few months back, among other things I put in a new heating element and it was working just fine. I went to use it yesterday and suddenly there is no heat.
I took it apart, I checked the heating element, all the thermostats, I took them off the dryer and the fuse.
Everything has continuity, I don't get it.
#2 Posted : Tuesday, August 14, 2012 2:29:43 PM(UTC)
Pull the dryer out of the wall and remove the terminal block cover. Check the power cord connection to the terminal block.
While the power cord is plugged into the wall outlet, measure the voltage between the black wire & the white wire and the red wire & the white wire. The normal readings suppose to be about 120 VAC. Measure the voltage between the black wire & the red wire. The normal reading suppose to be about 240 VAC.
Post the results.
Here are the breakdown diagrams and Replacement parts for General Electric DPSQ475ET0AA Electric dryer | AppliancePartsPros.com
CSteidl
#3 Posted : Wednesday, August 15, 2012 7:39:07 AM(UTC)
CSteidl
I performed the tests you suggested and I got the results we were looking for, Black & white was 120, red & white was 120 and black and red was 240.
#4 Posted : Wednesday, August 15, 2012 1:43:32 PM(UTC)
Remove the wires from the heating element terminals. Check for 120 VAC between each of the wires and the ground while the timer calls for heat. One of the wire should not have the correct reading. Trace that wire and post the results.
CSteidl
#5 Posted : Thursday, August 16, 2012 10:10:23 AM(UTC)
CSteidl
I did the testing, every wire tested 120, then I hooked the heating element back up and took a reading on both of those, it was 120. I don't know what to tell you. I've put the dryer all back together, theoretically it's going to work.
I'll let you know.....if it doesn't work I will probably buy a new dryer.
#6 Posted : Thursday, August 16, 2012 1:30:34 PM(UTC)
Originally Posted by: CSteidl Go to Quoted Post
...I hooked the heating element back up and took a reading on both of those, it was 120...
This result is incorrect. Can you describe more detailed how did you do this test please?
I could not find any electric schematic for this dryer. If you do have one and can post it here, it might help.
CSteidl
#7 Posted : Friday, August 17, 2012 5:09:13 PM(UTC)
CSteidl
I put one wire from my tester on the heating element and the other wire to a ground.
So I put the dryer back together and it works and I will go with the theory that one of those thermostatic units was stuck and jostling the dryer around shook it loose before I even took things apart and that's why they were all continuous.
Thanks for your help.
Guest (4)
Kenmore model 11060022010 electric dryer no heat (Dryer Repair)
by mike5466 5/1/2020 10:29:22 AM(UTC)
Speed Queen electric dryer no heat after 5 min. (Dryer Repair)
by napalm747 8/23/2014 6:05:30 PM(UTC)
electric dryer no heat - problem solved (Dryer Repair)
by JohnWMc 6/2/2014 3:17:26 PM(UTC)
Electric dryer no heat (Dryer Repair)
by Timothy Burt 4/10/2014 12:02:47 PM(UTC)
Whirlpool Electric Dryer No Heat (Dryer Repair)
by ahrjmrecr 10/30/2013 2:38:30 PM(UTC)
whirlpool duet electric dryer no heat (Dryer Repair)
by Reisingera03 2/6/2013 2:49:42 PM(UTC)
by livetoride2112 3/5/2012 5:24:19 PM(UTC)
Maytag Neptune Electric Dryer No Heat (Dryer Repair)
by jrvier 11/12/2011 3:31:42 PM(UTC)
kenmore electric dryer no heat (Dryer Repair)
by vito m 5/18/2011 6:00:36 PM(UTC)
Sears Galaxy Electric dryer no heat,timer doesn't move (Dryer Repair)
by melindascrochet 5/2/2011 7:38:20 AM(UTC)
Whirpool Electric Dryer No heat (Dryer Repair)
by flmeade 9/14/2010 8:38:15 AM(UTC)
EstateElectric Dryer No Heat (Dryer Repair)
by elaza 6/5/2010 8:00:42 AM(UTC)
by STEVE8369 3/16/2010 3:53:24 AM(UTC)
by MIKEK38E 2/9/2010 5:25:07 AM(UTC)
Electric Dryer NO HEAT (Dryer Repair)
by powers7000 11/1/2009 10:47:38 AM(UTC)
