ripitup
#1 Posted : 17 years ago
ripitup
Refrigerator has been sitting idle for a few years. Plugged it in
and the compressor won't shut off. Need help please!!
Thank You
#2 Posted : 17 years ago
What is the temperature inside?
ripitup
#3 Posted : 17 years ago
ripitup
After the fridge being on for 5 hours, the freezer is -10 and the fridge is 50*. It does shut off for the defrost mode. The fan in the freezer does not seem too work????????????Thanks
kooler
#4 Posted : 17 years ago
kooler
Locate the motor in the freezer and try spinning the blade by hand... It may just be a little rusty from sitting idle... Otherwise a new motor can be obtained from APPros but you'll need the complete model number to identify the replacement...
ripitup
#5 Posted : 17 years ago
ripitup
Thanks, ordering new motor. The compressor runs fairly loud, is this normal for this model. et20nkxxn01???
ripitup
#6 Posted : 17 years ago
ripitup
Anyone!!! Is the comp. on it's way out?
#7 Posted : 17 years ago
It's unpredictable. It could run with an excessive noise for a years or it could die pretty soon.
abbie
#8 Posted : 17 years ago
abbie
take and amperage draw on the compressor to see how hard it,s working ,if it,s 10% or more then what,s on the compressor plate or sticker I would SCRAP it.
Samsung compressor won't shut off - freezing food (Refrigerator & Freezer Repair)
by Mogal 10 years ago
Compressor won't shut off (Heating, Ventilation, and Air Conditioning (HVAC))
by wrichhel 17 years ago
