rrobleto
#1 Posted : Wednesday, August 1, 2012 3:11:49 AM(UTC)
rrobleto
I have this washer/dryer combo, the washer wont take water out, I changed the lid switch, the pump and nothing, can you please help?
Simon / APP Team
#2 Posted : Wednesday, August 1, 2012 11:08:15 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Set timer to drain and using the multimeter check if the drain pump is getting 120VAC.
If there is no voltage - trace the wires and check the disconnect plug. Also check the wires to the lid switch.
Post the results.
Here are the breakdown diagrams and Replacement parts for Frigidaire FEX831FS4 LAUNDRY CENTER | AppliancePartsPros.com
Thank you.
Simon.
rrobleto
#3 Posted : Wednesday, August 1, 2012 4:09:49 PM(UTC)
rrobleto
do you have the wiring diagram for this washer?, thank you
Simon / APP Team
#4 Posted : Wednesday, August 1, 2012 9:16:51 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The diagram should be inside the pocket on the back side of the panel above the washer.
Simon.
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
washer wont spin (Washer Repair)
by allen9258 4/8/2018 11:08:33 PM(UTC)
Maytag Bravos Washer wont spin (Washer Repair)
by utzzy27 10/2/2016 1:15:15 PM(UTC)
washer wont spin out (Washer Repair)
by dokratt 4/16/2016 2:50:25 PM(UTC)
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 11/17/2015 12:56:58 PM(UTC)
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
by Denarae 8/4/2015 7:21:30 AM(UTC)
Frigidaire Washer Wont spin high speed (Washer Repair)
by jchi2210 12/17/2014 12:01:09 PM(UTC)
washer wont spin& drain (Washer Repair)
by aristeoherrera@gmail.com 12/10/2014 3:19:57 PM(UTC)
by lvest 7/26/2014 11:09:50 AM(UTC)
by Mattbri 5/30/2014 11:16:21 AM(UTC)
ge profile washer wont spin (Washer Repair)
by ron1821 3/24/2014 4:57:26 PM(UTC)
GE profile washer wont spin (Washer Repair)
by ron1821 3/19/2014 11:31:36 AM(UTC)
Maytag washer wont spin, smoking from under and smells like burnt rubber (Washer Repair)
by trytodiy 3/13/2014 6:20:43 PM(UTC)
