Ive replaced the defrost timer and condenser fan motor and the condenser fan will not work. Everthing else works and the bottom of freezer gets cold but nothing else because the fan will not circulate the cold air. Ive looked for a schematic and cannot find one thinking that maybe there is a relay somewhere but I dont know. Any information would be helpful. Thank you.
The condenser fan is located next to the compressor. The evaporator fan is located inside the freezer section next to the evaporator coils.
So do you really mean condenser fan or did you mean evaporator fan?
i mean the fan inside i have replaced and is not working
