11 Pages«<7891011>
#81 Posted : Monday, July 9, 2012 5:41:02 PM(UTC)
What is the complete model number of the oven?
TractionAction
#82 Posted : Monday, July 9, 2012 7:07:47 PM(UTC)
TractionAction
Mine is the SCD272TS, approx 13 years old.
#83 Posted : Tuesday, July 10, 2012 4:01:25 PM(UTC)
If the square 4 prong connector is damaged then nothing is going to work. The correction is to replace the control panel. If you need the correct part number, post the color of the control panel.
Here are the breakdown diagrams and Replacement parts for Thermador SCD272T BUILT-IN ELECTRIC OVEN | AppliancePartsPros.com
TractionAction
#84 Posted : Tuesday, July 10, 2012 5:25:33 PM(UTC)
TractionAction
Thanks for the reply Gene. I did order the touch panel and it arrived today. Now I have new display, mating board and the touch screen. Still the display does not function and the oven does not even work. Including the oven light. I do have power to the oven itself. Please advise if there is anything else I can check.
New parts just received and installed.
AP2827874 (368772) Touch control gls w/fltr s272s
702451 : Bosch OVEN DISP REPAIR KIT For double ovens.
Thx,
Mike
#85 Posted : Tuesday, July 10, 2012 7:10:36 PM(UTC)
Mike,
Did you replace the relay board from the kit and the wire harness too?
TractionAction
#86 Posted : Tuesday, July 10, 2012 8:30:31 PM(UTC)
TractionAction
Gene,
Yes, both were replaced. I noticed the coil on the relay board did warm up a little, so I'm getting power to it.
Thx,
Mike
#87 Posted : Tuesday, July 10, 2012 8:57:41 PM(UTC)
Mike,
You may want to verify proper voltage at the oven terminal block. It suppose to read 120 VAC between the red wire & the white wire and between the black wire & the white wire. The normal reading between the red wire & the black wire suppose to be 240 VAC.
TractionAction
#88 Posted : Sunday, July 22, 2012 12:15:12 PM(UTC)
TractionAction
Thanks Gene...I checked the voltage, the voltage is correct as you stated. I powered the oven back on and still no display or any type of operation etc. Can you provide any other thoughts?
Simon / APP Team
#89 Posted : Monday, July 23, 2012 9:29:53 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
I may sounds annoying but you should check all the connections on the display and relay boards.
The 4 wire connector at the touch control may go in (unfortunately) the wrong way. Try to re plug it.
Simon.
TractionAction
#90 Posted : Thursday, July 26, 2012 8:22:25 AM(UTC)
TractionAction
I checked the connections, all are good. The 4 wire on the touch panel has a clip to line things up and is inserted per the clip. At this point I'm going to return the display kit as it may be defective.
UserPostedImage
11 Pages«<7891011>
