What is the complete model number of the oven?
Mine is the SCD272TS, approx 13 years old.
Thanks for the reply Gene. I did order the touch panel and it arrived today. Now I have new display, mating board and the touch screen. Still the display does not function and the oven does not even work. Including the oven light. I do have power to the oven itself. Please advise if there is anything else I can check.
New parts just received and installed. AP2827874 (368772) Touch control gls w/fltr s272s 702451 : Bosch OVEN DISP REPAIR KIT For double ovens.
Thx,
Mike
Mike,
Did you replace the relay board from the kit and the wire harness too?
Gene,
Yes, both were replaced. I noticed the coil on the relay board did warm up a little, so I'm getting power to it.
Thx,
Mike
Mike,
You may want to verify proper voltage at the oven terminal block. It suppose to read 120 VAC between the red wire & the white wire and between the black wire & the white wire. The normal reading between the red wire & the black wire suppose to be 240 VAC.
Thanks Gene...I checked the voltage, the voltage is correct as you stated. I powered the oven back on and still no display or any type of operation etc. Can you provide any other thoughts?
Groups: APP Team
Hi.
I may sounds annoying but you should check all the connections on the display and relay boards. The 4 wire connector at the touch control may go in (unfortunately) the wrong way. Try to re plug it.
Simon.
I checked the connections, all are good. The 4 wire on the touch panel has a clip to line things up and is inserted per the clip. At this point I'm going to return the display kit as it may be defective. ![UserPostedImage](http://i133.photobucket.com/albums/q42/TractionAction/touch_pad.jpg)
