3 Pages123>
wallywattz
#1 Posted : Wednesday, July 25, 2012 6:30:45 PM(UTC)
wallywattz
My dryer makes a squealing noise. It doesn't happen for the entire cycle - kind of in spurts.
I took off the front of the dryer to investigate. The dryer drum glides look okay to my untrained eye. I uploaded an image of the one that appeared to be a little more worn.
Also, the drum has some scratches grooved into it. Looks like it is rubbing against something that is digging into it. Do you think this is what could be making the squealing noise and if so, is it due to the drum glides not supporting the drum properly?
Thanks.
wallywattz attached the following image(s):
Simon / APP Team
#2 Posted : Thursday, July 26, 2012 10:17:51 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to check what's making this grooves on the drum. Also check the rear support rollers and shafts.
Provide the model number, so I can look up the parts.
Thank you.
Simon.
wallywattz
#3 Posted : Thursday, July 26, 2012 11:00:28 AM(UTC)
wallywattz
Not sure of the model number - where do I find that?
It is rubbing against this metal piece (blower housing?). Image attached.
wallywattz
#4 Posted : Thursday, July 26, 2012 11:23:17 AM(UTC)
wallywattz
Also, how do I know if the drum glides are worn out? They look okay to me, but I don't know what to look for.
Simon / APP Team
#5 Posted : Thursday, July 26, 2012 2:54:04 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The glide on the picture looks OK. Check the glide's bracket position: is it bent ? Check the felt seal.
The model number tag could be on the top of the control panel or inside the door and door frame.
Simon.
wallywattz
#6 Posted : Thursday, July 26, 2012 4:55:00 PM(UTC)
wallywattz
The brackets are slightly curved, by design I believe. They don't look abnormally bent.
I removed the drum and it is definitely the drum rubbing up against the metal housing of the blower, which means the drum is sitting too low in the front. So the question is, what is causing the drum to sit so low? The belt didn't appear too loose.
Simon / APP Team
#7 Posted : Friday, July 27, 2012 9:34:58 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please provide the model number, I need to see what I'm dealing with.
Simon.
wallywattz
#8 Posted : Friday, July 27, 2012 1:30:07 PM(UTC)
wallywattz
Model # is MDET236AYW
Simon / APP Team
#9 Posted : Friday, July 27, 2012 3:04:25 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the glide brackets ,felt pads, glides, felt drum seal.
Here are the breakdown diagram and Tumbler replacement parts for Maytag MDET236AYW DRYER- ELE | AppliancePartsPros.com
Simon.
wallywattz
#10 Posted : Tuesday, July 31, 2012 3:50:40 PM(UTC)
wallywattz
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
Anything specifically that I should be looking for in terms of wear? Everything looks okay to me.
Also, the dryer is only a year and a half old. Do any certain parts tend to go quicker than others (within this time frame)?
Kenmore Elite Oasis Dryer Squealing (Dryer Repair)
by Secret Ingredient 2/24/2017 5:01:06 PM(UTC)
Dryer squealing, now won't start (Dryer Repair)
by NetExtra 12/2/2016 1:54:42 PM(UTC)
Electric dryer squealing (Dryer Repair)
by kenbreedlove 1/15/2012 7:50:54 PM(UTC)
Dryer squealing (Dryer Repair)
by yme 11/5/2011 3:43:22 PM(UTC)
Dryer squealing and squeaking loudly (Dryer Repair)
by upmawmaw 4/3/2011 4:49:29 AM(UTC)
by mumkelly 10/27/2010 10:21:55 AM(UTC)
Kenmore HE2 Electric Dryer Squealing (Dryer Repair)
by thompsong 2/17/2010 5:56:06 PM(UTC)
Dryer squealing problem (Dryer Repair)
by Roarky24 10/14/2009 9:04:40 AM(UTC)
Amana Dryer Squealing LOUD (Dryer Repair)
by Clarene 2/5/2009 9:26:58 AM(UTC)
by mommykite 11/11/2008 6:58:33 AM(UTC)
Admiral Dryer squealing (Dryer Repair)
by tferg24 3/24/2008 3:23:28 PM(UTC)
3 Pages123>
