Brad Turner
#1 Posted : Monday, March 30, 2009 5:33:38 AM(UTC)
Brad Turner
My wife smelled something burning while drying a load of laundry so for what ever reason she unplugged the dryer from the 240VAC wall outlet. When she plugged it back up it would not work at all including no light. I can here the timer clicking once set. I checked the input power at the terminal strip (good) checked the thermal fuse dead short (good) checked for a overload protector on the motor not found. I also checked the on off switch which was .o1OHMS on or off with both wires disconnected. I shorted the wires and nothing. Tested door switch (good). Is there a glass or ceramic fuse on the unit?
any ideas please help. Oh yea I moved the unit drum around and one out of two of the heating elements lit up extremly hot and went off. I could not recreate the problem.
#2 Posted : Monday, March 30, 2009 6:03:33 AM(UTC)
Could not find a ADE70005AYW, so assumed this was just a typo following are for a ADE7005AYW
Replacement parts for ADMIRAL ADE7005AYW | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/m...ibrary/docs/16027525.pdf
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16026315.pdf
Did you check both sides of the line for 120 volts? The light uses one side of the line (120 volts) also the motor. Perhaps you have lost Neutral.
The overload is inside the motor
By on off switch I assume you mean the Push To Start, with the wires disconnected this does indicate a problem. It should open and close
No. Unit only has the one Item 6 in "Base, heater" section
From what I see the unit only has one heater.
Looks like you have the 240 volts as you had high heat.
By turning the drum, you turned the motor which closed the centrifugal switches and you had heat. Since the door was open air was not pulled over the heating element hence the extreme heat. You may have blown the thermal fuse or the heater itself.
Brad Turner
#3 Posted : Monday, March 30, 2009 6:51:03 AM(UTC)
Brad Turner
Is there anything I can jumper first to isulate the component?
The switch I was refuring to is the ON/OFF selector switch to the far left hand side that is showing .01OHMS in the off position.
Brad Turner
#4 Posted : Monday, March 30, 2009 6:51:58 AM(UTC)
Brad Turner
Were exactley is unit 6?
#5 Posted : Monday, March 30, 2009 7:38:02 AM(UTC)
I think that On/Off switch is for the end of cycle buzzer.
Item 6 is in the parts breakdown at AppliancPartsPros (1st link)
Should be on the heater case.
GE electric range - nothing works but the clock (Oven Repair (including Ranges and Cooktops))
by Jelltronic 5/15/2022 6:28:03 AM(UTC)
Thermador downdraft - nothing works - no buttons are illuminated (Oven Repair (including Ranges and Cooktops))
by blueindustries 9/7/2015 9:04:23 PM(UTC)
Replaced front burners and now nothing works (Oven Repair (including Ranges and Cooktops))
by Julie Lemoine 12/5/2014 4:51:01 PM(UTC)
Whirlpool Gold Nothing works (Dishwasher Repair)
by Brc187 6/23/2014 1:50:30 PM(UTC)
Oven had popping sound - nothing works (Oven Repair (including Ranges and Cooktops))
by DickB101 4/7/2013 9:59:31 AM(UTC)
Whirlpool Duet Sport Nothing Works (Washer Repair)
by luke.papp 11/4/2012 10:52:35 AM(UTC)
Nothing works: lights, fan, screen display (Microwave Repair)
by elainr123 8/21/2012 12:22:35 PM(UTC)
Short - Now nothing works (Oven Repair (including Ranges and Cooktops))
by mlab 4/28/2012 5:00:19 PM(UTC)
door dispenser dead, no lights, nothing works (Refrigerator & Freezer Repair)
by richlem 2/12/2012 5:02:45 PM(UTC)
nothing works (Washer Repair)
by 900hpv6tbird 2/1/2012 8:18:14 AM(UTC)
Nothing works but the light inside. (Refrigerator & Freezer Repair)
by 3505740 1/23/2012 8:40:51 PM(UTC)
Range "popped", nothing works (Oven Repair (including Ranges and Cooktops))
by ghettofreddy 1/17/2012 6:14:59 PM(UTC)
Kenmore Refrigerator nothing works. (Refrigerator & Freezer Repair)
by jyama99 11/10/2011 10:05:10 PM(UTC)
Power but nothing works (Washer Repair)
by Bellamorabito 9/24/2011 6:10:17 AM(UTC)
Nothing works but it does have power (Oven Repair (including Ranges and Cooktops))
by lbaker 5/3/2011 9:29:42 AM(UTC)
