lbaker
#1 Posted : Tuesday, May 3, 2011 9:29:42 AM(UTC)
lbaker
Oven & range don't work, no diplay when knobs are in the off posion but when I turn a burner on i get a display of 40 for a few seconds then it goes to the time which is wrong. HELP
#2 Posted : Tuesday, May 3, 2011 6:28:18 PM(UTC)
If neither the oven nor surface burners don't work, there is something wrong with the power source.
Pull the range out of the wall. Remove the rear cover and check the voltage at the terminal block.
Here are the breakdown diagrams and Replacement parts for AMANA AER5515QAW RANGE- S/C F/S ELE | AppliancePartsPros.com
