Hock
#1 Posted : 13 years ago
Hock
We had a power surge, bump, etc. during the night. I reset the clock in the morning and all seemed OK. The ceramic cook top functions OK. However, went to use the oven and when I touched bake the lock light began flashing. I tried broil and the same thing happened. I then locked the door and tried to initiate the self cleaning cycle and after a few seconds I would receive the error code f9. The door lock mechanism appears to work perfectly. The door lock switch I tested for continuity and when the switch is pressed ohms read 1 when not depressed the meter reads nothing. I have cycled the power on and off several times to no avail. Help!!!!!
Simon / APP Team
#2 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
Try to unlock the key pad:
press STOP TIME and CANCEL at the same time for 5 sec.
If that doesn't help - replace the clock/control board
Part number: 5701M680-60
Here are the breakdown diagrams and Replacement parts for Maytag PER5710BAW RANGE- S/C F/S ELE | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Hock
#3 Posted : 13 years ago
Hock
I already tried to unlock the key pad. I have ordered the clock control board. I will let you know if it works. Thanks
Simon / APP Team
#4 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Hock
#5 Posted : 13 years ago
Hock
I forgot to ask how do I get to the control board to replace it?????
Simon / APP Team
#6 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
Unplug the unit.
Remove the rear control panel cover.
Simon.
Hock
#7 Posted : 13 years ago
Hock
Just got the Control Board changed it in 10 minutes and oven works great, Thanks again!!!!!!!!!!!!!!!!!!!
Jim
Simon / APP Team
#8 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Kenmore gas range oven won't work (Oven Repair (including Ranges and Cooktops))
by shirleyjones 8 years ago
oven won't work properly randomly (Oven Repair (including Ranges and Cooktops))
by miklos 9 years ago
by b2bq 11 years ago
Kenmore oven won't work. Stovetop still works but neither bake nor broil will heat (Oven Repair (including Ranges and Cooktops))
by dangole104 12 years ago
GE Built-In Gas Oven Won't Work Even After Replacing Parts (Oven Repair (including Ranges and Cooktops))
by kimpossible 12 years ago
Oven won't work after the self cleaning cycle (Oven Repair (including Ranges and Cooktops))
by sluggermike 13 years ago
Kitchen Aid oven won't work after cleaning cycle (Oven Repair (including Ranges and Cooktops))
by geopharmer 14 years ago
Denman please help! Oven won't work. (Oven Repair (including Ranges and Cooktops))
by johnrp99 14 years ago
Maytag Gemini Upper Oven won't work (Oven Repair (including Ranges and Cooktops))
by mleslie 14 years ago
Oven won't work after self-clean. (Oven Repair (including Ranges and Cooktops))
by tandg98 14 years ago
Replaced bake element,but oven won't work (Oven Repair (including Ranges and Cooktops))
by ant1828 14 years ago
Clock & numbers dimming now oven won't work (Oven Repair (including Ranges and Cooktops))
by pennym363 14 years ago
by bmoore201 14 years ago
The bake button of walloven won't work. (Oven Repair (including Ranges and Cooktops))
by jakyl07 15 years ago
Whirlpool oven won't work!! (Oven Repair (including Ranges and Cooktops))
by serenity of three 15 years ago
