Hock
#1 Posted : Wednesday, June 20, 2012 10:30:03 AM(UTC)
Hock
We had a power surge, bump, etc. during the night. I reset the clock in the morning and all seemed OK. The ceramic cook top functions OK. However, went to use the oven and when I touched bake the lock light began flashing. I tried broil and the same thing happened. I then locked the door and tried to initiate the self cleaning cycle and after a few seconds I would receive the error code f9. The door lock mechanism appears to work perfectly. The door lock switch I tested for continuity and when the switch is pressed ohms read 1 when not depressed the meter reads nothing. I have cycled the power on and off several times to no avail. Help!!!!!
Simon / APP Team
#2 Posted : Wednesday, June 20, 2012 12:08:21 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Try to unlock the key pad:
press STOP TIME and CANCEL at the same time for 5 sec.
If that doesn't help - replace the clock/control board
Part number: 5701M680-60
Here are the breakdown diagrams and Replacement parts for Maytag PER5710BAW RANGE- S/C F/S ELE | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Hock
#3 Posted : Thursday, June 21, 2012 6:03:30 AM(UTC)
Hock
I already tried to unlock the key pad. I have ordered the clock control board. I will let you know if it works. Thanks
Simon / APP Team
#4 Posted : Thursday, June 21, 2012 9:54:24 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Hock
#5 Posted : Friday, June 22, 2012 6:52:57 AM(UTC)
Hock
I forgot to ask how do I get to the control board to replace it?????
Simon / APP Team
#6 Posted : Friday, June 22, 2012 10:06:31 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Unplug the unit.
Remove the rear control panel cover.
Simon.
Hock
#7 Posted : Friday, June 22, 2012 11:11:22 AM(UTC)
Hock
Just got the Control Board changed it in 10 minutes and oven works great, Thanks again!!!!!!!!!!!!!!!!!!!
Jim
Simon / APP Team
#8 Posted : Friday, June 22, 2012 12:28:39 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Kenmore gas range oven won't work (Oven Repair (including Ranges and Cooktops))
by shirleyjones 12/14/2016 10:41:41 AM(UTC)
oven won't work properly randomly (Oven Repair (including Ranges and Cooktops))
by miklos 9/29/2016 2:36:35 AM(UTC)
by b2bq 6/11/2014 9:26:03 AM(UTC)
Kenmore oven won't work. Stovetop still works but neither bake nor broil will heat (Oven Repair (including Ranges and Cooktops))
by dangole104 2/18/2013 7:22:38 PM(UTC)
GE Built-In Gas Oven Won't Work Even After Replacing Parts (Oven Repair (including Ranges and Cooktops))
by kimpossible 1/17/2013 4:30:57 PM(UTC)
Oven won't work after the self cleaning cycle (Oven Repair (including Ranges and Cooktops))
by sluggermike 11/24/2011 12:37:19 AM(UTC)
Kitchen Aid oven won't work after cleaning cycle (Oven Repair (including Ranges and Cooktops))
by geopharmer 3/9/2011 7:18:14 AM(UTC)
Denman please help! Oven won't work. (Oven Repair (including Ranges and Cooktops))
by johnrp99 2/23/2011 12:38:43 PM(UTC)
Maytag Gemini Upper Oven won't work (Oven Repair (including Ranges and Cooktops))
by mleslie 2/21/2011 5:50:47 PM(UTC)
Oven won't work after self-clean. (Oven Repair (including Ranges and Cooktops))
by tandg98 2/21/2011 5:19:51 PM(UTC)
Replaced bake element,but oven won't work (Oven Repair (including Ranges and Cooktops))
by ant1828 2/19/2011 12:52:32 PM(UTC)
Clock & numbers dimming now oven won't work (Oven Repair (including Ranges and Cooktops))
by pennym363 12/21/2010 5:05:46 PM(UTC)
by bmoore201 10/23/2010 7:46:50 AM(UTC)
The bake button of walloven won't work. (Oven Repair (including Ranges and Cooktops))
by jakyl07 8/11/2010 8:42:16 AM(UTC)
Whirlpool oven won't work!! (Oven Repair (including Ranges and Cooktops))
by serenity of three 7/28/2010 2:37:15 PM(UTC)
