dmonica922
#1 Posted : Sunday, March 29, 2009 8:16:16 PM(UTC)
dmonica922
After moving the dryer across the room I have noticed moisture on the floor around the dryer. It is properly vented, and never did this before.
Any suggestions?
kayakcrzy
#2 Posted : Monday, March 30, 2009 3:33:40 AM(UTC)
kayakcrzy
Yes, the reason you have condensation on the floor is because the vent is clogged to the outside. You need to clear it out. Tom ApplianceEducator.com
#3 Posted : Monday, March 30, 2009 3:50:11 AM(UTC)
If the vent is clear and the vent louvers are opening correctly.
Check that the vent pipe is sealed at the dryer's exhaust.
If the unit is on a concrete slab and the above is OK, try the following.
Let the floor dry.
Get a 1 foot square or so piece of clear plastic (no holes)
Tape this down onto the floor where the moisture is the worst.
Run the dryer.
If the moisture is on top of the plastic it is from the dryer.
If it is under the plastic you are pulling moisture up through the slab.
ray4005
#4 Posted : Monday, June 25, 2012 5:21:25 PM(UTC)
ray4005
Originally Posted by: kayakcrzy Go to Quoted Post
Yes, the reason you have condensation on the floor is because the vent is clogged to the outside. You need to clear it out. Tom ********************************************
make sure the duct is connected to the air duct assembly. this happened to me could not figure it out till i took it back apart. I guess when i moved it back in the room the duct moved side ways causing a small gap. the exhaust duct must be sticking straight out. check the screw to make sure it tight.
kayakcrzy
#5 Posted : Tuesday, June 26, 2012 2:33:44 AM(UTC)
kayakcrzy
Yo Ray!!! This post is only 3 years, and 3 months old!!! LOL!! By this time they probably have a new dryer!!! LOL!!!
Ice dispenser condensation (Refrigerator & Freezer Repair)
by Guest 6/16/2022 10:57:08 AM(UTC)
Condensation PSS26SGPA SS (Refrigerator & Freezer Repair)
by B_Moon 1/23/2022 11:06:36 AM(UTC)
GE Refrigerator Flapper Condensation Buildup (Refrigerator & Freezer Repair)
by larsnilsen 5/10/2021 4:16:43 AM(UTC)
Ice dispenser door seal condensation (Refrigerator & Freezer Repair)
by JoePilot@sprynet.com 10/28/2012 5:14:07 PM(UTC)
Condensation on inside of dryer door (Dryer Repair)
by TexAg156 7/29/2012 6:28:27 AM(UTC)
Condensation problem - is it un-fixable? (Refrigerator & Freezer Repair)
by kevin_bkt 6/21/2012 7:46:44 AM(UTC)
Condensation on outside of ice chute flap.. (Refrigerator & Freezer Repair)
by FDAR 2/12/2012 8:52:30 AM(UTC)
Cannot connect condensation tube to new detergent dispenser (Dishwasher Repair)
by davidlin 9/2/2011 1:53:34 PM(UTC)
Refrigerator leaks condensation onto the floor (Refrigerator & Freezer Repair)
by david51 8/5/2011 3:59:14 AM(UTC)
Condensation/water inside refrigator (Refrigerator & Freezer Repair)
by LJ Franklin 7/12/2011 7:29:49 PM(UTC)
Bosch Axxis Condensation Dryer (Dryer Repair)
by eamiller11 10/20/2010 9:27:01 AM(UTC)
Condensation on back side of Refig/Freezer (Refrigerator & Freezer Repair)
by clintvic 9/29/2010 5:07:07 PM(UTC)
Removing condensation vent from soap dispensor (Dishwasher Repair)
by Mongillo 9/13/2010 11:53:46 AM(UTC)
Freezer condensation (Refrigerator & Freezer Repair)
by drip 7/5/2010 6:21:21 PM(UTC)
Excessive condensation in refrigerator (Refrigerator & Freezer Repair)
by conan646 3/10/2010 8:18:33 AM(UTC)
