my refrigerator runs condensation onto the floor. I've already changed the door seals and cleaned the coils. What's the problem??
Originally Posted by: david51  my refrigerator runs condensation onto the floor. I've already changed the door seals and cleaned the coils. What's the problem?? David, Since you never mentioned where the water accumulates, or appears to be dripping from, it'll be a bit rough. You may want to start by checking the ice maker water supply tube(s) and valve, in back of the refrigerator. When you cleaned the condenser coil, did you notice if the condenser fan motor was running at a proper speed, and you're sure the new door seals are sealing to the front of the fridge, all the way around both doors ? Good Luck, :) :) :)
