art1028
#1 Posted : Saturday, March 28, 2009 8:42:12 AM(UTC)
art1028
Tested element,meter shows continuity. hi limit switch also checks heated and cooled to be good. thermal cut off checks no continuity. part # 3398671 is this the prob to no heat in dryer? thanks Art
#2 Posted : Saturday, March 28, 2009 9:32:36 AM(UTC)
Here is the part
Part Details - WHIRLPOOL Thermal cut-off for dryer heating element 360 degrees (includes high-limit thermostat), part number: 279769
Note it comes with a new high limit thermostat.
Yes: this will kill the heat if open.
They sometimes just blow on their own but things to check as possible causes are:
1. Be sure to clean/check your vent system and the blower wheel.
2. Ripped drum seals. If no good air is pulled into the drum here instead of being pulled through the heater assy.
3. Cycling thermostat contacts welded together.
4. Lint filter coated with fabric softener residue.
As you can see most of them have to do with air flow
art1028
#3 Posted : Sunday, March 29, 2009 10:36:09 AM(UTC)
art1028
Originally Posted by: denman Go to Quoted Post
Here is the part
Thanks for the re: Denman!! Will order part tomorrow am. Again many thanks Art
Thermal fuse ratings and interchangeability on dryers (Dryer Repair)
by Guest 12/17/2023 10:57:55 AM(UTC)
Kenmore Dryer blowing thermal fuses (Dryer Repair)
by Marius 11/21/2023 2:26:28 PM(UTC)
Thermal fuse blown repeatedly (Dryer Repair)
by Guest 3/5/2023 6:13:36 PM(UTC)
Thermal Fuse on KitchenAid KDTE304DSS0 (Dishwasher Repair)
by jztjzt 7/24/2022 7:04:23 PM(UTC)
Matag Bravos gas dryer thermal fuse (Dryer Repair)
by Maytag Bravos Fool 11/29/2021 4:32:35 AM(UTC)
Magic Chef thermal fuse equivalent (Microwave Repair)
by bassclef78 10/13/2021 9:40:22 AM(UTC)
KitchenAid Dishwasher KUDS30IXBL Thermal Fuse (Dishwasher Repair)
by Ed Explains It 3/16/2021 10:34:44 AM(UTC)
Whirlpool Duet Dryer - WED9200SQ0 - Thermal Fuse (Dryer Repair)
by cjmatthes 1/17/2020 2:09:48 PM(UTC)
Electrolux dryer thermal fuse (Dryer Repair)
by Lillydz101 8/14/2019 8:59:05 PM(UTC)
Kenmore Elite dishwasher 665.13112K700 blows thermal fuse (Dishwasher Repair)
by rrsteven 10/31/2018 9:02:16 PM(UTC)
Dryer too hot flips the thermal fuse (Dryer Repair)
by Maverick1 12/6/2017 6:29:07 AM(UTC)
Whirlpool Dryer keeps blowing thermal fuse (Dryer Repair)
by MSUspartan25000 9/6/2017 3:11:10 PM(UTC)
Ikea Whirlpool IBS550PWW00 In wall oven Control Thermal Fuse?? (Oven Repair (including Ranges and Cooktops))
by teamlouish 3/29/2017 3:54:29 PM(UTC)
Whirlpool dryer-thermal fuse keeps blowing (Dryer Repair)
by daddjdom 3/28/2017 9:44:13 AM(UTC)
Kenmore problems/thermal fuse/temp adjustments (Dryer Repair)
by Kruegerk 2/12/2017 5:07:37 PM(UTC)
