waterdogs
#1 Posted : Thursday, March 26, 2009 2:56:32 PM(UTC)
waterdogs
8 CYCLE makes the lights blink and goes click click click when it goes from aggatate to pump/spin if i stop it and advance the timer it workes great.
#2 Posted : Friday, March 27, 2009 5:17:00 PM(UTC)
Would it drain and spin if you advance the timer? How far should you move it?
ufmq502710
#3 Posted : Friday, March 27, 2009 5:35:03 PM(UTC)
ufmq502710
I would like to know if the motor itself for GE Profile range hood can be fixed. I'm talking about just the motor. The whole assy is too expensive. Any suggestions? M#jv635h1ww s#dg8019642
Thxs
ufmq502710
#4 Posted : Friday, March 27, 2009 5:39:05 PM(UTC)
ufmq502710
Need to know if motorf can be fix to avoid buyint the whole assy.
:( :mad:
ufmq502710
#5 Posted : Friday, March 27, 2009 5:41:46 PM(UTC)
ufmq502710
:( :mad:
Please reply, I'm new to this site?????
Need suggestion on how to fix this motor:mad:
#6 Posted : Friday, March 27, 2009 5:45:07 PM(UTC)
No, the motor is not serviceable. It comes as an assembly only.
- The part number for the blower motor assembly is AP3792681
Here are the break down diagrams and Replacement parts for GE JV635H1WW | AppliancePartsPros.com
waterdogs
#7 Posted : Saturday, March 28, 2009 3:54:31 PM(UTC)
waterdogs
yes it drains and spins fine if I advance the timer. I just have to move it ahead a tad. Thanks
#8 Posted : Saturday, March 28, 2009 4:10:59 PM(UTC)
I would suspect the timer. The model number you posted is incorrect. I believe it should be TAWS700EQ1 instead of TAW5700EQ1. Verify and repost it.
