AppliancePartsPros.com
Appliance Repair Help
Washer Repair
washer shorts out between aggitate and pump/spin
8 CYCLE makes the lights blink and goes click click click when it goes from aggatate to pump/spin if i stop it and advance the timer it workes great.
Would it drain and spin if you advance the timer? How far should you move it?
Originally Posted by: Gene  Would it drain and spin if you advance the timer? How far should you move it?
Gene. I would like to know if the motor itself for GE Profile range hood can be fixed. I'm talking about just the motor. The whole assy is too expensive. Any suggestions? M#jv635h1ww s#dg8019642 Thxs
Need to know if motorf can be fix to avoid buyint the whole assy. :( :mad:
Originally Posted by: ufmq502710  Need to know if motorf can be fix to avoid buyint the whole assy. :( :mad: Please reply, I'm new to this site????? Need suggestion on how to fix this motor:mad:
yes it drains and spins fine if I advance the timer. I just have to move it ahead a tad. Thanks
I would suspect the timer. The model number you posted is incorrect. I believe it should be TAWS700EQ1 instead of TAW5700EQ1. Verify and repost it.
Washer Repair
